Zetec conversion parts
Doing a Zetec conversion on a MK2 XR2 and need some parts.
Remember years ago you could get anything you wanted no probs but everything seems thin on the ground now!
I'm after a cvh efi flywheel & clutch and a Zetec 4 branch manifold.
Can anyone help me out?
Grant
Grant
Zetec parts are getting slim pickings what with the age, kitcars, other rwd ford stuff and a lot of the banger racing moving from pinto to zetec.
The cvh efi flywheel is particularly rare. You would have more luck with the standard 1.8 Zetec flywheel and clutch and that should work for you just the same.
If your looking for a fwd manifold the st170 manifold is cheap, flows well and is easy to modify.
From what I can gather the rs turbo cvh clutches fit the flywheels for zetecs that had the IB5
Thought as much, so I defo need a cvh efi flywheel.
Any of you know if a non efi cvh clutch would work on an efi flywheel?
Say an XR2 or mfi rst clutch? I seem to remember they are a different size?
We used a 2.0l silver top in ours ,bought it all second hand off a guy breaking his mk4 he had it all in ,we bought the lot, engine, gearbox clutch flywheel all as a job lot so i could not tell you what was used as we just put it straight in ours ,we do use rs turbo gearboxes though
All the 1.8's accept the 130ps had the smaller 220mm flywheel.
The 1.6 silvertop is the same part the latter 1.6 zetec se is totally different.
The cvh efi flywheel is like finding unicorns and only has a tiny weight saving.
![](https://cimg7.ibsrv.net/gimg/passionford.com-vbulletin/1500x2000/img_20190726_135555_a8a51ed83bb37d19f04627a2ffac2dcaad3e19eb.jpg)
![](https://cimg8.ibsrv.net/gimg/passionford.com-vbulletin/1500x2000/img_20190726_135540_a484351dec63fa5e45f979993c42b763ceb241f4.jpg)
Can anyone tell me if I can remove the pats system on this or does it all need to be retained?
I know you get internal and external pats but unsure which one this is?
Grant
That’s a 130 ps ecu. Escort / Orion I am pretty sure it won’t be pats.
The body control / alarm unit cuts the earth to various circuits to Immobilise it. That’s going to be the black box with the wires all the same colour.
Pats is dead easy , you can’t bypass it but its very easy to use and you get obd2 so you can see what the engine is doing on your phone.
Escort, Focus Rs even the 3.0 Mondeo st220 it all works the same way.
cossie4i+
Ford XR Parts For Sale
23-08-2015 10:31 AM
jaw
30-06-2010 12:26 AM
ShandzS1
11
13-04-2008 09:59 AM
