Cosworth rear diff oil leak
hi al
My diff is leaking oil between the prop/flange on the rear diff,would i be right in thinking its coming down the splines,and leaking from the thread of the nut.
thanks in advance
Matt
thanks in advance
Matt
4 bolts pull the prop off and pop the seal out
Did you sort yours?
yep ,all done
its not the seal,take the flange off,smear a load of gasket sealer(i used threebond),onto the splines.slide it back on making sure you see the sealer squige out around where the nut goes on,replace nut,re tighten,job done .
I've removed the nut already before and put a load of sealer around it which cured it for a while....
But I done it again last week and it lasted a week!!
Did u take the flange of and seal it?It has that washer under the 24mm nut which I couldn't get out??
I used loctite 5900 which is normally shit hot stuff
Thing is its a fully recon gripper diff which has done appx 600 mile at Ł1200!!!
id take the diff back
try using a semi-hardening sealer,if it goes hard,it'l just crack and leak again
i took the flange off,made sure it was dry and clean,smear some under the washer too
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
xr4x4rs
Aug 6, 2015 09:03 PM
