Electronic boost controller
Old Apr 24, 2014 | 09:15 AM
timsrs's Avatar
timsrs
Default Electronic boost controller
I have bought an GReddy profec electronic boost controller, the latest model...
i get setting the boost etc, but what does the " gain" mean ??
What does the gain do??
Any info on setting and gain would be appreciated
Tim
Old Apr 24, 2014 | 05:08 PM
funkyboozer's Avatar
funkyboozer
I think, from memory of mine, it's a percentage of the max it can handle.
Mine is a 2.5 bar version so 100 is 2.5 bar. 50 would be 1.25 bar.
Old Apr 24, 2014 | 05:24 PM
stwibs's Avatar
stwibs
does this help ??
http://forums.evolutionm.net/evo-how...b-spec-ii.html
Old Apr 24, 2014 | 08:36 PM
timsrs's Avatar
timsrs
Yes good find
So gain looks like a percentage of the set boost
Originally Posted by stwibs
Old Apr 25, 2014 | 04:35 AM
davidfox280585's Avatar
davidfox280585
im under the understanding of with mine,
set = desired boost
gain= is after boost as peaked and dropped gain will add back to desired boost level,
set gain= start boost
warning is visible
warning limit will limit the boost
does this help
the last screen is highest recorded boost,push the knob in to reset this its a very good tool knowing how much boost its recorded every run
Old Apr 26, 2014 | 11:43 AM
timsrs's Avatar
timsrs
Many thanks
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
