Mk1 escort cosworth not starting
I am trying to get the car running after a 2 year rebuild, and this is what happens....
The car will start ( better when cold) then run for approx 4 seconds the dies. it then will fail to start until its been left for a while, then the same happens.
It looks as it its getting no pressure, i did remove the feed line to the rail and had plenty of fuel come through, and i have a spark. I did clamp the return hose and car seemed to run, so i replaced the fuel regulator with a new item but its still the same.
Not sure which way to turn now, can't believe its been 2 years and its come to this...
HELP, HELP, HELP
HELP, HELP, HELP
It runs now thanks..It was pump & map wire come out of plug..
Can you help me with my other post
https://passionford.com/forum/old-sk...tem-setup.html
Tim
Tim
