Problem with water pump 4x4
Old Apr 19, 2014 | 08:13 PM
thundercos's Avatar
thundercos
Default Problem with water pump 4x4
Hello, I have a new engine 4x4 and I have buy a new water pump.
But this pump is no good because her body is at 1mm to the belt.
See the picture:
She come from this Ebayer:
http://www.ebay.co.uk/itm/COSWORTH-Y...:X:AAQ:GB:1123
Then impossible to use this parts!!
someone has you there had the same problem?
Old Apr 19, 2014 | 09:19 PM
jon@work's Avatar
jon@work
which way did you turn the cambelt tensioner to put tension on the belt ?
it needs to be turned clockwise before you tighten the lock nut
Old Apr 19, 2014 | 09:28 PM
Cossy Mike's Avatar
Cossy Mike
As above ^^^^
Crack off the lock nut and turn the tensioner the opposite way, it will bring the belt away from the pump
Old Apr 19, 2014 | 10:22 PM
thundercos's Avatar
thundercos
Everything is ok at the level of the timing of the distribution. Besides this is not my first YB.
Loock this others pictures , you can see the old pump, 1 cm to the belt like this.
thundercos's Avatar
thundercos
Old Apr 19, 2014 | 10:51 PM
christer_martinsen's Avatar
christer_martinsen
The water pump which is shown in the last pictures, is a 2wd pump. Not 4x4 water pump. The 4x4 water pump has thicker body, and is therefor closer to the timing belt.
Old Apr 20, 2014 | 06:59 AM
thundercos's Avatar
thundercos
Yes I know but not like this. You can see that it's impossible to use without crash to the belt in few kilometers.
Old Apr 20, 2014 | 09:10 AM
thundercos's Avatar
thundercos
For the little story this is to put on a new engine T25. I have buy without water pump.
In my car when I come back to France.
that the raison because I put a new water pump. And of course I don't like plug a bad pump.
Old Apr 20, 2014 | 09:32 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
You tensioner is clearly tensioned in the wrong direction.
Old Apr 20, 2014 | 10:05 AM
thundercos's Avatar
thundercos
No it's good because like you have made the belt touch the housing thermostat.
Many motor have broken as here.
The distribution shall be adjusted from the factory on my engine.
Old Apr 20, 2014 | 10:21 AM
DixieTheKid
Pick-up P100 Power!
No I haven't ?
Old Apr 20, 2014 | 10:31 AM
DixieTheKid
Pick-up P100 Power!
Even with it tensioned clock wise mine still doesn't fail on water pump. So my guess would be you belt is stretched.
Old Apr 20, 2014 | 10:44 AM
thundercos's Avatar
thundercos
Be careful because your belt is too close to the housing. 1 or 2mm is too short to the beat of the belt
This is a known issue in the world of the cosworth
look at your picture, the belt is not at the middle of the down carter
and on my engine it is perfectly centered
and you can look on the other engines
another one
My problem is clearly the pump, she is no good.
My question was, someone has you there had the same problem?
Old Apr 23, 2014 | 12:19 PM
thundercos's Avatar
thundercos
I think that I'm going to buy another pump at Burton.
Old Apr 24, 2014 | 08:41 AM
DaveCrack's Avatar
DaveCrack
Had the same Problem with a new pump I bought. Compared to another Escort 4WD pump we had lying around the casting was way thicker and no chance to clear the belt at all. I ended up sending it back. I have no idea off which engine it came but clearly it doesnt belong to the YB.
Old Apr 24, 2014 | 08:58 AM
thundercos's Avatar
thundercos
Thank you for your information.
It is possible that it passes on a Pinto simple tree but I am not sure.
Me too I've returned the pump.I'm waiting for what it me reference money.
Old Oct 30, 2015 | 04:57 PM
M K's Avatar
M K
I have this same problem but I am going to linish a section of the pump body to give back the clearance,
Mine is a genuine ford pump but my arse is I have had it machine to suit a 10 stud set up
Is this common?
Old Nov 2, 2015 | 01:04 PM
DaveCrack's Avatar
DaveCrack
I ended buying up buying a new pump as the used one I got was fucked too.
Its not genuine but a good re-cast from the original manufacturer.
It came from Motomobil and fits and works fine. No problems with the timing belt.
With the strong Pound vs. Euro you might get a cheap replacement buying in Germany although the pump was sold by a distributor from UK.
http://www.motomobil.com/wasserpumpe...0243200-1.html
FlashRS
Sep 14, 2015 12:36 PM
Adam-M
Aug 26, 2015 05:53 PM
cameron2
Aug 25, 2015 07:18 AM
kosienutter
31
Aug 22, 2015 09:55 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
