Focus rs Cams
Old Apr 18, 2014 | 07:00 PM
Churtz's Avatar
Churtz
Default Focus rs Cams
Evening all.
Can someone confirm for me that a mk1 focus RS uses different cams to the 2.0 zetec blacktop?
Many thanks.
Matt
Old Apr 18, 2014 | 07:20 PM
jonfoc's Avatar
jonfoc
I'm lead to believe they are the same. Use a 1.8 inlet cam for a better response
Old Apr 18, 2014 | 08:06 PM
Churtz's Avatar
Churtz
Well I've now been assured that the 1.8 and 2.0 cams are the same. I've read that the focus rs boys use a 1.8 can for better response..... Means the frs cams must be different?
Old Apr 18, 2014 | 08:11 PM
studabear's Avatar
studabear
I was under the impression the frs had unique cams :unsure:
Old Apr 18, 2014 | 09:32 PM
jonfoc's Avatar
jonfoc
Having had a focus RS which was fitted with a 1.8 inlet cam, I can tell you the engine and car were completely different after fitting. So from that I can only presume that the 1.8 and 2.0 are different.
Old Apr 19, 2014 | 08:07 AM
IanC's Avatar
IanC
The frs cams arnt the same as any other zetec there unique to the frs
Old Apr 19, 2014 | 10:00 AM
Churtz's Avatar
Churtz
Ok cool. Next question, does anyone know the ident code for the frs cams.... They use ident rings for part numbers so its something like 01010 (standard 2.0 cam) .. OR anyone have a pic of FRS cams?
Thanks
Old Apr 19, 2014 | 03:02 PM
IanC's Avatar
IanC
I'll see what I can find for you pal think I've got a set of cams in the garage I'll have a look when I get home
Old Apr 19, 2014 | 09:23 PM
Churtz's Avatar
Churtz
Thanks mate!!
Old May 19, 2014 | 09:07 PM
hodgebull's Avatar
hodgebull
hi looking for a exhaust cam for a frs anyone help
Old Aug 12, 2014 | 09:09 AM
RSRick3290's Avatar
RSRick3290
Iv just bought piper cam pulleys and have a 1.8 inlet cam im putting into my FRS has anyone tried different degrees on the 1.8 cam or is std best ?
cos elle
Sep 25, 2015 09:52 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
