Ford Puma Discuss the Ford Puma here!
Puma 1.4 running issue
Old Apr 6, 2014 | 06:05 PM
Leejd's Avatar
Leejd
Default Puma 1.4 running issue
Hi, I'm currently building a 1.4 puma rally car I'll be using the standard 1.4 sigma lump but I'm struggling to get it running right. It idles at 1500rpm and when dropping from higher revs holds at 2000rpm only noticeable thing is when the clutch is pressed the revs drop straight to 1000rpm but then climb back to 2000rpm currently I have changed the tps and icv every vacuum pipe coming off the throttle body and cleaned the butterfly I've also cleaned the maf I've replaced the clutch position sensor aswell but the problem is still the same I've tried to disconnect the maf and speed sensor but both just make the car stall straight away, any help would be really appreciated also this morning I found the crankshaft breather had a split in it I replaced this but still have the issues
Old Apr 6, 2014 | 06:18 PM
Leejd's Avatar
Leejd
I've also fully tested the power steering sensor
Chas
Sep 21, 2015 08:57 PM
Bailes1992
Sep 3, 2015 02:17 PM
Ben26
Aug 11, 2015 04:19 PM
Red_bull
Aug 9, 2015 08:34 AM
