Ford Puma Discuss the Ford Puma here!
Help needed with ecu/immobilzer issue.
Old Apr 2, 2014 | 02:50 PM
benh2014's Avatar
benh2014
Default Help needed with ecu/immobilzer issue.
hi all im a newbie to this.
im after some help and/or advice.
I have a w reg puma 1.7 and I have lost all spark, fuel pump, and starter. iv read that the led light should flash then when you turn on the ignition the light should stay on for 3 seconds then turn off.
iv checked the fuses and relays and they are all ok.
I have a TAPE ecu and have been told that I cannot unlock it.
can anyone help. cheers in advance.
Ben.
Old Apr 2, 2014 | 04:54 PM
GVK.'s Avatar
GVK.
What does the PATS light do when you turn on the ignition?
Either way really will need a session on Ford IDS to diagnose/repair, maybe a key problem, or PATS reciever ring on the igniton lock.
Old Apr 2, 2014 | 05:00 PM
benh2014's Avatar
benh2014
it flashes like normal, when I put the key in and turn on so all the lights come on the light stops flashing.
am I right in thinking it should come on for 3 sec solid then go off?
thanks
Old Apr 2, 2014 | 05:51 PM
GVK.'s Avatar
GVK.
If its a key problem the light will flash rapidly.
Old Apr 2, 2014 | 05:59 PM
benh2014's Avatar
benh2014
yeah I read that on the net somewhere, but cant seem to find if it not coming on for 3sec is normal or not? at the same time I cant seem to find a ecu to replace it with.
thanks
Old Apr 2, 2014 | 06:08 PM
GVK.'s Avatar
GVK.
This is from Autodata..
System operation
  • System arms 5 seconds after switching ignition OFF.
  • Switch ignition ON.
  • Ensure clock LED illuminates for 3-5 seconds.
  • If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals:
    Old Apr 2, 2014 | 06:30 PM
    benh2014's Avatar
    benh2014
    thanks for that.
    by that it would mean that as my light doesn't come on and stay on for 3-5sec my key may have lost its code?
    iv tried it several times and still the same, so if my key has lost its code that would make sense.
    I was driving home from the docs only 1/4 mile and turned left got to change from 2nd to 3rd gear and the car cut out. when I stopped I tried to restart the car and it just turned over. so I left it for the day and tried the next it turned over but no start for about 3/4 times then I tried again nothing. ignition lights come on sometimes the dash doesn't tell me the millage and no pump priming.
    if I turn the key quickly on and off a few times the car makes a beep and the light stays on for 2sec then goes off but still the same.
    a strange one!
    thanks
    Old Apr 2, 2014 | 06:40 PM
    GVK.'s Avatar
    GVK.
    On the mileage display does it show ------ ?
    Had this before where there's a short on a 5v reference sensor circuit on the engine, it shuts the ECU down.
    Old Apr 2, 2014 | 06:47 PM
    benh2014's Avatar
    benh2014
    yeah ------ or sometimes just blank
    where would I check for a short 5v reference sensor circuit on the engine
    Old Apr 2, 2014 | 06:52 PM
    GVK.'s Avatar
    GVK.
    Any sensor that has 5v feed to it.. such as throttle postion sensor, cam sensor if 3 wire, maf/tmap sensor (depends whats fitted)
    On the car I had it on was a Mondeo mk1 V6 years ago.. the TPS wiring was melted against the EGR pipe.
    Disconnect the throttle position sensor, then with ign on see if it has 5v on one of the terminals, if it hasn't it points to a short on the 5v reference circuit..it could be anywhere...
    Really needs diagnostics doing to see if any codes to help pin it down...
    Old Apr 2, 2014 | 07:37 PM
    benh2014's Avatar
    benh2014
    thanks for your help, I will check them well what I can anyway. I think may be best to take it in that case.
    just don't want to spend a fortune.
    thanks for your help.
    JoeyBoyden
    Jan 4, 2024 02:36 PM
    borboyous
    Aug 22, 2015 11:17 AM
    Anutternutter
    Aug 21, 2015 06:07 PM
    yawiejon
    15
    Aug 9, 2015 06:36 PM
    col93saphcos
    Aug 7, 2015 03:21 PM
