Digital ACT Gauge that can use original ACT sensor
Old Mar 11, 2014 | 12:20 PM
Sonic Boom's Avatar
Sonic Boom
Default Digital ACT Gauge that can use original ACT sensor
I'm after a digital ACT gauge that can read the siginal that comes off of Cossies original ACT sensor.
Just like a SECS gauge but obviouly alot smaller and only reads ACT and doesn't require a Webber ECU.
Any ideas guys?
Cheers Rich
Old Mar 11, 2014 | 12:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Pretty sure mike rainbird does one like that mate
Old Mar 11, 2014 | 12:55 PM
jontysafe's Avatar
jontysafe
Yes R & B`s use existing Ford fittings but isn`t the standard ACT sender quite slow? Plus you have the problem of heat soak.
I`ve just fitted this with the sender between intercooler and throttle body (where I have moved Weber ACT sender to as well):
http://prosportgauges.com/intake-temperature-gauge.aspx
Old Mar 11, 2014 | 01:19 PM
Sonic Boom's Avatar
Sonic Boom
Yup already moved mine to the outlet of intercooler pipe, I just want an incar indicator of what ACT the ECU is seeing.
Rich
Old Mar 11, 2014 | 07:08 PM
Sonic Boom's Avatar
Sonic Boom
Anyone else?
Bump for the evening crew
Cheers Rich
DixieTheKid
11
Jun 6, 2020 11:20 AM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
