Pad cleaning on da polisher
Old Mar 6, 2014 | 09:55 AM
neilmanfocus1's Avatar
neilmanfocus1
Default Pad cleaning on da polisher
Ok, just purchased a das-6 da polisher and my question is, how do you go about cleaning the pads and how often during the process of polishing your car do you clean them? There is loads of things on the internet about techniques on how to polish your car but not many idiot guides for people like me on how to clean the pads and how often. Any real world advice from you guys would be great, thanks👍
Old Mar 6, 2014 | 04:26 PM
Brian's Avatar
Brian
Use one of these mate http://www.ebay.co.uk/itm/like/13054...ff14=95&ff19=0
Brian
Old Mar 6, 2014 | 04:35 PM
neilmanfocus1
You would use that after doing 2 or 3 passes on the car then? What does it actually do? I can't see how that actually cleans the pad?
Old Mar 6, 2014 | 04:40 PM
opposite lock's Avatar
opposite lock
Follow this guide as you cant go wrong.
http://www.detailingworld.co.uk/foru...ad.php?t=63859
Make sure you prime the pad prior to your polishing set , you wont need to clean for quite a while but basically its something you pick up as you go along.
Definately look at that link and stick the kettle on.
Mike
Old Mar 14, 2014 | 06:34 PM
Retro Al's Avatar
Retro Al
RWD IS KING
You need a pad washer bucket,fill it 3/4 full of water open the sides, place the machine with pad on the wheels inside and run the machine
Old Mar 14, 2014 | 06:36 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Old Mar 14, 2014 | 08:40 PM
neilmanfocus1
That looks awesome, may have to invest!! How often during polishing your car should you clean the pad though? For eg, would you polish quarter of the car,clean pad, polish another quarter, clean pad, etc etc??
Old Mar 15, 2014 | 05:50 PM
Retro Al's Avatar
Retro Al
RWD IS KING
You can clean it after each set, or just clean it when it start to look a bit glogged with polish
Old Mar 15, 2014 | 07:31 PM
neilmanfocus1
When you say each set are you referring to doing the whole car with a harsher polish/pad combo then a softer pad/finishing polish etc?
Old Mar 15, 2014 | 07:39 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Best way is to just check the pad regular and clean when it looks a little glogged up,compounds tend to glog the pad up quicker than say a finer finishing polish etc.
You will see when your doing it.
Old Mar 21, 2014 | 02:50 AM
Jean Comolli's Avatar
Jean Comolli
All pads have a performance cycle, meaning you will get the desired results only to a certain point on that curve. The point of declining performance is typically reached by polish / compound pad being overloaded with product; you should always be able to see the individual cells or texture of the pad, with proper, regular cleaning pad overload can be avoided.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
caprixpack
Sep 25, 2015 07:53 PM
