Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Startup help please!
Old Feb 15, 2014 | 05:09 AM
joshsparkes's Avatar
joshsparkes
Default Startup help please!
Hey guys, I have a ford focus mk1 1.6 petrol 2004 plate coming up to 70k miles. I've just driven my car for 10 mins got out went into a shop for 3 mins came back, started my car and it struggled to start. It took 6 times for the start up motor to kick in and start the engine (this has never happened before). After this I turned the engine off and restarted again and it started as normal after 2 times of the start up motor. Any ideas? Thanks
Old Feb 15, 2014 | 01:22 PM
joshsparkes
Bump.
Old Feb 15, 2014 | 01:46 PM
GVK.'s Avatar
GVK.
Do you mean when you turned the key nothing happened, you then tried 6 times then it turned over, or did it turn over in the first place?
Old Feb 15, 2014 | 02:21 PM
davidfox280585's Avatar
davidfox280585
fuel pumps are common for intermittent starts but ideally you need to type more info for anyone to help you diagnose
Old Feb 15, 2014 | 03:38 PM
joshsparkes
I only turned the key one but it took 6 times for the engine to kick in.
Old Feb 15, 2014 | 03:47 PM
GVK.'s Avatar
GVK.
So did it turn over when you turned the key?
Or did it turn over and not start?
Old Feb 15, 2014 | 03:49 PM
joshsparkes
Yes I only turned the key once and it turned over 6 times.
bigspj
Jan 7, 2010 08:16 PM
sjm
Feb 28, 2007 07:48 PM
Dave McB
Jan 20, 2006 01:11 PM
Speedy G.
Ford Escort RS Cosworth
Apr 14, 2004 08:22 PM
CosRush
Computers, Consoles and I.T.
Mar 14, 2004 04:24 PM
