2.2 TDCI turbo actuator
Old Feb 13, 2014 | 02:28 PM
gazza2502's Avatar
gazza2502
Default 2.2 TDCI turbo actuator
As above its sticking , i have removed the circlip & tryed to free it , it moves now but is not as smooth as it should be . Is there any way i can clean the variable veins without removing the turbo ? I put EGR cleaner into the turbo from the inlet side a month ago & it worked for a while , but really need to get some into the exhaust side.
Old Feb 20, 2014 | 12:45 PM
gazza2502's Avatar
gazza2502
Thinking about drilling a hole into the exhaust side of the turbo , then tapping it so i can put a small bolt in it to reseal it . Then i will be able to put some cleaner in through the hole . Will this work ?
Old Feb 20, 2014 | 12:52 PM
cossie rs500's Avatar
cossie rs500
10 Year Member
try innotec vnt cleaner,,,,,,,, its a pain in the arse i have a skoda 1,9tdi and have the same problems,,,,
Old Feb 20, 2014 | 01:48 PM
gazza2502's Avatar
gazza2502
Thats the stuff i used.
Old Feb 20, 2014 | 02:50 PM
cossie rs500
10 Year Member
in my car i delete the egr pass and inshide i throw the cleaner to unblock the sticking vanes,,,,, but its not permanent ,,, the problem come back after some kmh ,,,,,
Old Feb 20, 2014 | 07:08 PM
gazza2502's Avatar
gazza2502
Anyone ? will this work ?
Old Feb 20, 2014 | 09:10 PM
gazza2502's Avatar
gazza2502
Bump , before i do this , got to be cheaper than a new turbo , if it works.
Old Feb 26, 2014 | 04:38 PM
gazza2502's Avatar
gazza2502
Well hole drilled & tapped , Mr Muscle oven cleaner in . & the shite that came out the exhaust was unbelievable . Car now works as it should & no more glow plug light.
Old Feb 26, 2014 | 10:27 PM
gazza2502's Avatar
gazza2502
Took it for a good run , MPG is going up & it only cost me £3 & half an hour of my time . Borrowed a right angled chuck & tap & die set.
Old Feb 27, 2014 | 03:54 AM
cossie rs500
10 Year Member
can you take a foto of the position of the driling ,,,,, i want to make the same but i am afraid to damage the vanes ,,,
Old Feb 27, 2014 | 01:26 PM
gazza2502's Avatar
gazza2502
Old Feb 27, 2014 | 01:33 PM
gazza2502's Avatar
gazza2502
Old Apr 28, 2014 | 10:46 PM
Jonny5H's Avatar
Jonny5H
wow what a great couple of videos, will be checking the actuator travel properly tomorrow.
Old May 4, 2014 | 12:36 PM
gazza2502's Avatar
gazza2502
It worked for me car still fine
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
