oil in fuel filter
Old Feb 12, 2014 | 12:00 PM
garfield65's Avatar
garfield65
Default oil in fuel filter
I have just changed the oil filter on my mk3 mondeo 2.0ltr diesel. when I drained the fuel out there was quite a lot of jet black oil. this don't sound good. as anyone got any ideas what could have caused it ......thanks
Old Feb 12, 2014 | 12:06 PM
stevieturbo's Avatar
stevieturbo
C**t
Where do you buy your fuel ?
Old Feb 12, 2014 | 12:54 PM
garfield65's Avatar
garfield65
Any where from shell to esso to bp.
Old Feb 12, 2014 | 02:13 PM
I cant see how the oil has got into the fuel system.
Old Feb 12, 2014 | 02:33 PM
russ rs's Avatar
russ rs
If second hand car could be petrol mixed and bits from tank or pump partials maybe
Old Feb 12, 2014 | 02:47 PM
stevieturbo
C**t
If the pump has issues, that is one possibility. Not sure if the injectors use oil pressure at all on those engines or reside where contamination might be possible
Old Feb 12, 2014 | 02:51 PM
James @ M Developments.'s Avatar
Hang on,
you just changed your OIL filter, but were draining fuel out of it? that doesnt make sense,
There should be oil in the oil filter that would be normal.
If you have made a typo and you have changed the fuel filter, and found oil in there, it would be worth looking into what is going down the return line back into the fuel tank from the engine, as you may find it is oil contaminated, either that or someone has been adding oil to the fuel at some point which would be a little odd.
Old Feb 12, 2014 | 08:13 PM
garfield65's Avatar
garfield65
I meant fuel filter sorry. When these gales have gone I will check fuel return thank you. I don't think oil is in the fuel tank. I have had the car 2years.
Old Feb 12, 2014 | 08:37 PM
stevieturbo
C**t
Well if it is in the filter, it is also in the tank. It may not have originated in the tank, but it will be in there too via the return
Old Feb 12, 2014 | 08:45 PM
Csm's Avatar
Csm
I know its not a vag engine but the 2.0 tdi vag engine has been known to have this problem and is caused by a Tandem Pump on the engine that is also a vaccum pump, the seals leak and let oil mix with the fuel. causing poor start/running/missfires etc etc
Just incase there is a similar pump on your engine a wee heads up.
Or just purely really shit fuel from somewhere
Old Feb 12, 2014 | 08:59 PM
stu21t's Avatar
stu21t
My old merc sprinter van had oil/diesel mixed.
The problem with it was it would over run when turned off due to burning the oil.
All the fuel lines in the engine bay are see through in them and mine were black.
Turned out to be something simple like an oil seal gone in a pump
Old Feb 12, 2014 | 09:11 PM
garfield65's Avatar
garfield65
My fuel lines are all black. I think I will get a manual and check if there are oil seals in the pump. Thanks
Old Feb 12, 2014 | 09:13 PM
garfield65's Avatar
garfield65
I will also check to see if it as got a tandem pump. Thanks
Old Feb 13, 2014 | 05:35 AM
My mates vw caddy van had problems with the injector seals leaking fuel into the engine oil lol. Vw wanted 3k to fix it.
Old Feb 13, 2014 | 09:12 AM
chink's Avatar
chink
weve had a few like this glenn at work vw also told us it need a new head as injectors had worked loose
oil level was crazy high with fuel was quite funny
Old Feb 13, 2014 | 11:11 AM
garfield65's Avatar
garfield65
bloody hell glen HOW much. I think I might dig a big hole and bury it lol.
Rob Wells
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
dombanks
Sep 21, 2015 08:38 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
