Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus c max, error code p0238
Old Feb 11, 2014 | 04:16 PM
andrewmctiernan's Avatar
andrewmctiernan
Default Focus c max, error code p0238
hi all,
just had this come up on the OBD equipment, the engine light is on and the turbo isnt boosting, is this usually a replacment turbo?
rather than replace can they be rebuilt? just looking for the cheapest option
many thanks
Old Feb 11, 2014 | 04:49 PM
little bram's Avatar
little bram
I wouldn't be changing the turbo just on a fault code you'll need to do some more testing. what is the code description?
Old Feb 11, 2014 | 04:52 PM
andrewmctiernan
p0238 - Turbocharger Boost Sensor (A) Circuit High Input is present
Old Feb 11, 2014 | 05:00 PM
Doug's Avatar
Doug
There is a boost control valve bolted to the rear of the engine brown in colour if it's a dv6 1.6tdci I would be checking in that area first , vac lines no leaks and also electrical connector .
Regards Doug
Old Feb 11, 2014 | 05:04 PM
andrewmctiernan
I'll be honest it came in as a part ex and im deciding whether to fix it or put to the auction, local lad rebuilds turbos for Ł175
thanks guys
Old Feb 13, 2014 | 02:51 PM
andrewmctiernan
it was the boost control valve, many thanks
Old Feb 13, 2014 | 03:00 PM
Doug's Avatar
Doug
Smile
Glad you sorted it .
Regards Doug .
Old Feb 14, 2014 | 05:11 PM
andrewmctiernan
and the next issue and i believe a common one, it has the odd hesitation at low revs, is it worth some injector cleaner and decent diesel?
155lee
Oct 27, 2015 04:55 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Sep 8, 2015 05:13 AM
ST-170
Sep 4, 2015 11:02 AM
