4x4 sump gasket
Planning on doing the 4x4 gasket this weekend, came to the unit to and no oil leaking from sump ? yes before the jokes start it does have oil in it
any ideas? no oil on the floor or leaking etc ..
has it repaired it self after the drive out on sunday ?
thanks
thanks
they don't have a sump gasket, it's a liquid gasket used on them
it may also be leaking from the o-ring on the side the diff goes into or the other side of the transfer shaft
and it's not as easy as "whipping off the sump" either as there is a fair amount of mechanicals to deal with, 5 hours in a garage with ramps and stuff it took when i did mine last time around
it came from the bolt heads but today ive had nothing not a drop
checked oil levels all ok not low , so im puzzled
Mc5506
Oct 5, 2015 09:57 PM
