Cmax
OK. To cut a long story short. 2006 Cmax 1.6Tdci (90) engine. 2 months since owning and I get car cuts out after starting with warnings of stearing failure and engine fault on the LCD screen. Car will either move very slowly or not at all. Restart car and all is good. Its ittermitant so the car will work fine occasionally. Fault code when I got one was U0155 lost com's with instrument cluster. Checked fuses and wiring into fuse box all ok. Any ideas? Thanks
Possibly a bad connection inside the instrument cluster. Replaced a few now. Take the instrument cluster out and wiggle it about while its plugged in and running. See if any warning messages pop up.
Thanks for the reply. This will be what I check next. I,m thinking take out and clean with wd40 and dry if it shows a warning message? My wife tells me the car is now showing engine management light. I can't fault check the error code till she gets back. I'll post it in the morning.
E management light switched itself off. Same code as before on fault reader. Did a self check on the car and see the battery was only giving 11.9V and after starting went up to 13.9-14. Took for a short drive and left car for 10 mins tried self test again and batt was 9.9v started up drove down road and car cut out with the same faults. So getting a new batt tomorrow and see if the fault happens again.
It took a few seconds to start. I'm guessing it used all the battery's power to start and that's why it cut out just down the road. At least I'm hoping that's the case. Heard so many stories of failed egr valves, turbos sooted up etc. I'm gonna give it a oil service this week also as I here the engines in these are a bit fussy.
OK just an update. Wasn't the batt but needed a new one anyway. Haven't had time to take out cluster yet but looked around it today while engine was running and noticed a mark at the top which looks like its been taken out before. Put a little pressure on the cluster and it instantly threw up a load of faults and cut acceleration. So my plan is to take it out and see what's what. Did some research and this is a known manufacturing fault with Ford. Water seeps in under the window due to poor beading/seals into the cluster. It was on watchdog in 2008. Affects fiestas, focus and cmax. Ford will fix and replace cluster for £99 if your car is proven to be defected. Think I'll try cleaning it myself first before giving any money to Ford just yet.
