Ford KA Discuss your Ford KA here!
airbag light on solid on streetka
Old Jan 23, 2014 | 04:24 PM
turbohurky's Avatar
turbohurky
Default airbag light on solid on streetka
Hi i have tried the following
1. plugged a code reader in and there are no codes stored
2. checked the yellow wire plugs and they are fine unclipped and clipped together again
what should i try next as the light stays on all the time
cheers in advance
lee
Old Jan 23, 2014 | 05:15 PM
oldford's Avatar
oldford
What code reader (make, type) did you use?
Old Jan 23, 2014 | 05:18 PM
turbohurky's Avatar
turbohurky
maxscan reader its never let me down YET lol
Old Jan 23, 2014 | 05:49 PM
oldford's Avatar
oldford
Any specific type or number for this code reader?
Because most of them only use EOBD/OBD2 protocols, which gives you (limited) access to the engine and automatic gearbox ecu's. Not supported are Abs, Airbag, etc., etc.
I think you should try again with a Ford specific code reader.
Old Jan 23, 2014 | 06:02 PM
turbohurky's Avatar
turbohurky
hi do you know if the ford f super on ebay are any good?
Old Jan 23, 2014 | 06:21 PM
london_chris's Avatar
london_chris
it would need to be reading airbag codes and not engine management codes?
some scanners only read engine
Old Jan 23, 2014 | 06:35 PM
turbohurky's Avatar
turbohurky
just got one that can read airbag codes
Old Jan 23, 2014 | 06:37 PM
GVK.'s Avatar
GVK.
If the light is on permanently there will be a code in the airbag module, as above, needs reading with something different.
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
cossiestu
Sep 19, 2015 05:19 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
