Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Are They The Same Engine ?
Old Jan 23, 2014 | 06:19 AM
Wizhunter's Avatar
Wizhunter
Default Are They The Same Engine ?
Hi Guys
I know this is a silly question,but,here goes.I went on EBay looking for a few bits for my car.And for you that have used ebay you know that on some items you put your car year ,type , and engine size and when you look for a part it tells you if it will fit..Well apparently My Ghia Saloon 1.8 isn't the same as the 1.8 Hatch..because it always comes back that it won't fit my car ?
I am totally baffled by this
Wiz
Old Jan 23, 2014 | 07:20 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's engine then it will either be zilver top or black top
the rest of it engine wise is excatly the same
Old Jan 23, 2014 | 12:07 PM
martysmartie's Avatar
martysmartie
The silvertop is the 1600 as fitted to the later Escorts, AFAIK there is only one variation of the 1800 and they all had a plastic cam cover.
Martin
Old Jan 23, 2014 | 02:20 PM
doga-ot's Avatar
doga-ot
the ecu's are also mapped differently and some cam profiles differ
Old Jan 23, 2014 | 06:26 PM
martysmartie
If this is true, then it will be an age related thing.
For a given engine it's the same across the board, regardless of body type.
Later 1600's had the revised 'phase two' engine, nevertheless though it's still the same engine.
Martin
Old Jan 23, 2014 | 08:57 PM
Wizhunter's Avatar
Wizhunter
Well thanks for the reply's guys..its just that i have to replace the vss and when i put the details into the ebay thing the majority say doesn't fit this engine ?
Old Jan 23, 2014 | 09:14 PM
doga-ot's Avatar
doga-ot
what car is it for? if its for a focus it doesn't matter what engine as the vss goes into the top of the gearbox
Old Jan 24, 2014 | 12:10 PM
martysmartie
I guessed you might have been using the compatibility chart in Ebay, don't take much notice of this, it isn't accurate!
Martin
Old Jan 24, 2014 | 03:38 PM
Wizhunter's Avatar
Wizhunter
Ok guys thanks very much for the help
Wiz
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
