Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
speedo not working from time to time
Old Jan 14, 2014 | 08:14 PM
Daniel-1986's Avatar
Daniel-1986
Default speedo not working from time to time
noticed yesterday that my speedo had dropped to 0 whilst driving but the rest of the clocks were working fine as normal, whilst the speedo is reading 0 the car will stall when u press the clutch but it will kick back to life after bump starting it again, ideas as read on other forums as possible VSS
its a 1.8 petrol mk1 focus with IB5 'box
Old Jan 14, 2014 | 08:27 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
V.S.S all day long. Dont suppose you notice if the stereo went quieter at the same time?
Old Jan 14, 2014 | 08:30 PM
Daniel-1986
Nope, tho Ive got an aftermarket sony headunit
Old Jan 14, 2014 | 08:35 PM
CosworthGuy
3dr Cosworth owner
Thats answers that then lol. My uncles focus did exactly the same as you describe and we changed the vss and no bother ever again. Its a real common thing with them
Old Jan 14, 2014 | 08:39 PM
Daniel-1986
Are they easy to replace, seen some horror stories of them breaking when removing plus they aint a cheap part to buy, by the looks of it on ebay, bout £50 for a genuine part
Old Jan 14, 2014 | 08:59 PM
Snyx's Avatar
Snyx
Plenty of lubrication/WD40/etc when you go to remove the VSS from the gearbox! They can be a bit of a pain in the arse to remove, but mole grips + patience and you will get there in the end
Old Jan 14, 2014 | 09:04 PM
Daniel-1986
Just watched a video on youtube of someone removing one, luckily for the tight space around it ive got smallish hands, if the worst happens and the pin breaks how u remove it then
Old Jan 14, 2014 | 09:14 PM
Snyx's Avatar
Snyx
If the pin breaks you'd be in trouble
I've done plenty of these though and never broken a pin, a small pair of mole grips on the pin and get it twisting and you'll be fine. Soak the VSS in WD40 the night before you do it and it should help! I find getting the pin out is the hardest bit, removing the actual sensor isn't too bad.
Old Jan 14, 2014 | 09:21 PM
Daniel-1986
Cool mite give it a go, do these have an average length of time before they completly die after they start playing up
Old Jan 14, 2014 | 09:32 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I agree with it being the vss. The speedo dropping to zero and the stalling part are the signs it's going. There is a vid on youtube.
Old Jan 20, 2014 | 07:53 AM
Wizhunter's Avatar
Wizhunter
I am having the same problem and was told it was the gearbox sensor which i gather is a vss..
Found The Link..Looks A pain to do.
Old Jan 20, 2014 | 09:44 AM
Daniel-1986
Touch wood mines been ok since last tuesday
Old Jan 21, 2014 | 09:10 PM
m1ke's Avatar
m1ke
Just ordered one for mine... its been playing up for months but got much worse the last few weeks! Fingers crossed it's not too much of a pain to fit
Old Jan 21, 2014 | 09:28 PM
Wizhunter's Avatar
Wizhunter
Can i ask how much you paid and is it a genuine ford part or aftermarket one ?
Old Jan 23, 2014 | 06:41 PM
m1ke's Avatar
m1ke
It's not a genuine one but comes with a 2 year guarantee so thought I would take a chance on it.. Was £25 delivered including the pin from ebay (rtgroup11)
jimmy oldskool
Aug 4, 2015 06:54 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
jimmy oldskool
Aug 4, 2015 07:06 AM
Escortdriver1
Jul 31, 2015 02:36 PM
