PAS Bracket Gasket on block?
Good Afternoon,
Was hoping someone would be able to help me here!
I'm putting my engine back together and noticed that i have a gasket which is supposed to sit between the block and the PAS bracket.
Now, does anyone know if there's supposed to be a gasket here? In the workshop manual it mentions just to use gasket sealer and NOT a gasket, however i've been supplied one?
Could anyone advise please?
%20(2).JPG)
Thanks
Thanks
I had this same confusion on mine, I had 2 sizes for the gasket, one much thicker than the other and it said to use sealant on 4wd.
If you look at the block I'm sure it doesn't actually need it, as said above it's a pinto thing
Yeah that's the one mate! It's like a thick plastic piece.
I assume you didn't use either then?
Mc5506
Oct 5, 2015 09:57 PM
