Urgent help needed!
Was putting the finishing touches to the head rebuild on my Saff tonight, timed it up and put the belt on then turned the engine by hand to double check the timing.
Problem is, the cam belt tensioner seems to be sitting too close to the head and is pulling the belt towards the back of the cam pulleys.
Should there be a spacer between the head and tensioner (I don't know if there was one on there before as the tensioner was still on the head when I took it to the engineers) and if so where can I get one tomorrow, or does anyoe know how thick it needs to be so I can try and find something else to use?
If the pulleys are on the wrong way round then they will sit out further than they should which is why i mentioned it mate!
I'll go and look at a tensioner and head in the garage just to confirm there is no spacer gimme a sec
Cheers again mate, must be what it is.
Shitting meself about what the heads gonna be like now though if I can't trust the fucker to put the cam wheels on properly
Didn't even give it a thought that it may have been something he'd done as I've heard nothing but good stuff about his work (the head and valve seats are perfect) just instantly assumed it must have been a spacer or something missing
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
