Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Fuel fittings
Old Jan 5, 2014 | 02:03 PM
timsrs's Avatar
timsrs
Default Fuel fittings
I am looking into the fuel system on my mk1 cosworth.
I will be running copper 8mm pipe under the car with braided at both ends. Opening up the outlet at bottom of the tank..
I think I am going to run a swirl pot in the system.
Is there anything available that can connect braided to the copper hard lines.
What does the -6 &-8 mean on the aeroquip fittings.
Old Jan 13, 2014 | 05:13 AM
canzus's Avatar
canzus
Whats a henway?
The -6 or -8 is the inside diameter of the tube in 16ths of an inch, so a -6 would be 3/8s", and the -8 would be 1/2"...
As for attaching braid to pipes, there are adapters and unions to do it...
borboyous
Aug 22, 2015 11:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
