Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Mk1 Escort Brakes
Old Dec 29, 2013 | 08:58 AM
timsrs's Avatar
timsrs
Default Mk1 Escort Brakes
I have a Mk1 escort running AP 4 pots on the front with cosworth rear calipers & discs.
Bias pedal box with girling master cylinders.
I have been having alot of trouble bleeding which i put down to bad master cylinders which were changed, and now i get a firm pedal but it has a long travel. its near the floor before it has any affect.
They do lock the hubs, but is near to the floor.
i am sure that all the air is out, and have would the rear calipers up fully to take up any slack.
How do you fine tune the calipers or take up the slack when the pads wear.
Any ideas on long pedal travel and the cause.
Need so assistance on what to do next.
Many thanks
Old Dec 29, 2013 | 10:09 AM
rs clint's Avatar
rs clint
insane
They should work OK you could take it to garage or maybe fit a remote servo hope this helps
Old Dec 29, 2013 | 05:17 PM
bignud's Avatar
bignud
had the same problem with mine. do you move the rear calipers to the top of the disc when you bleed them?
Old Dec 29, 2013 | 06:05 PM
graham c's Avatar
graham c
mite need bigger master cylinder as the four pots will take lots of fluid the move
Old Dec 31, 2013 | 09:10 PM
timsrs's Avatar
timsrs
Graham this was exactly the problem.....
I swapped the front & rear cylinders as a few people have sugested.
i now have .625 rear & .700 front....works well although not driven on road as its still being rebuilt ,but the pedal has only a small amount of travel.
I did have to lengthen the pushrod for the front cylinder which improved it further still.
Can you explain why lenthening the pushrod to the front improved things..
cheers Graham
Old Jan 1, 2014 | 09:03 AM
graham c's Avatar
graham c
The front are big calipers so takes lots of fluid
Old Jan 1, 2014 | 10:01 AM
timsrs's Avatar
timsrs
Think i need to setup pedal box still a bit further,making sure cylinders are equal when bias is in the centre...dont think its far out..
I know things will improve once bedded in as well....
Old Jan 1, 2014 | 07:56 PM
graham c's Avatar
graham c
just had an idea you could use the accumalater pump from a seirra to boost the brakes , resevior to pump to pedal to brakes
Old Feb 19, 2014 | 10:23 PM
Terry s Webb's Avatar
Terry s Webb
Do I need two servoes to run a bias peddel box on x mk1 escort thanks
Old Feb 19, 2014 | 11:40 PM
rsminter's Avatar
rsminter
i think you can buy a dual circuit servo (not cheap though) but a lot,me included just run a single circuit remote on the fronts.
Old Jul 3, 2014 | 08:35 PM
mk2 mike's Avatar
mk2 mike
You need to swap back the cylinders. Smaller number always on the front because internals are smaller so it pushes more fluid. On The rear the internals are bigger so pushes less fluid. The 625 goes on the front and 700 rear.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
