3 door cosworth fuel pump switch
Old Dec 8, 2013 | 01:47 PM
xr2i_boi's Avatar
xr2i_boi
Sam
Default 3 door cosworth fuel pump switch
Hi guys and girl I'm looking for the fuel pump cutoff switch. ......I've had a look in the spare wheel well and o/s kick panel. ..... nothing
can anyone help
Old Dec 8, 2013 | 03:06 PM
The Youth.'s Avatar
The Youth.
not certain the 3dr actually had them
i'm thinking that they didn't
steve
Old Dec 8, 2013 | 03:07 PM
GVK.'s Avatar
GVK.
Think only the Sapphires had them? Again,not 100% sure.
Old Dec 8, 2013 | 05:31 PM
xr2i_boi's Avatar
xr2i_boi
Sam
I've had a look........ looks like I need a new fuel pump
Old Dec 8, 2013 | 05:34 PM
martysmartie's Avatar
martysmartie
You won't, as they don't have one!
What testing have you done to condemn the pump?
Martin
Old Dec 9, 2013 | 06:01 AM
xr2i_boi's Avatar
xr2i_boi
Sam
There's power going to the pump but the pump isn't making a single bit of noise there's no sign of life there
Old Dec 9, 2013 | 11:25 AM
opposite lock's Avatar
opposite lock
Make sure your earth for pump is good. A common upgrade on these cars is to rewire the pump circuit , maybe a good time if the pump is shot.
Old Dec 9, 2013 | 11:40 AM
xr2i_boi's Avatar
xr2i_boi
Sam
Where can I get that from
Old Dec 9, 2013 | 12:25 PM
martysmartie
The likes of 'MSD'.
Also as said check the ground is ok, also if it has been allowed to run low on fuel the pump may have sucked dirt off and jammed it?
Martin
Old Dec 10, 2013 | 11:05 PM
PAUL S's Avatar
PAUL S
they do seize up on occasion if they dry out, a good clout with the wood end of a hammer can sometimes clear the obstruction
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
COSWORLD
Aug 14, 2015 07:40 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
