Mondeo 55 tdci 130, won't start
Old Dec 6, 2013 | 07:50 PM
matti231074's Avatar
matti231074
Default Mondeo 55 tdci 130, won't start
Hi, new to forums, had a problem with my mondeo, last week it start by taking twice as long to start than usual, first thought battery on the way out, charged and still took ages to start, but at least it did!, next while on a 30 mile journey, the car suddenly went into limp mode, turned it off and had the glow plug light illuminated, removed key/reset and it restarted ok, next day would not start again, changed the fuel filter ran it a bit all seems to be getting better. Day later would not start again, cracked the top of the injectors to ensure fuel getting through, finally it started and ran for over 100 miles all ok, now will not start again, any advice would be much appreiciated, or has anybody encountered this issue, or am i doing something wrong, thanks
Old Dec 9, 2013 | 11:02 AM
leep27's Avatar
leep27
Injectors. Having the same trouble with mine. Did a leak off test and it's not maintaining fuel rail pressure. It's leaking way too much fuel, which Knocks it into limp mode then cuts out. Now taking way longer to fire up than it used to, Pressies for the kids or 4 injectors???
Old Dec 9, 2013 | 06:40 PM
matti231074
Thanks for your response Leep27, do you know what cost will be?, 80000 miles, what a bag of shit, or is it time to part ex this bag of shit, i ain't got an endless pot of gold,
Old Dec 9, 2013 | 06:47 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
It may not be injectors - Have the fault codes read. It could be something as simple as a Crank Sensor. But if the codes do point to the injectors - it's time to get shot, as it won't be cheap.
Old Dec 9, 2013 | 06:59 PM
leep27's Avatar
leep27
I can't afford all in one go. Ł150 each is the current rate. So Ł600 and that's if you can do it yourself. As I can so guess I'm lucky. I am doing one at a time. I did the first one. It cured it for 2 months. But it's started again so I can just about scrape enough together for two more this week. But as previous guy says. Get it fault code checked. I get "P1211 injector control pressure higher/lower than desired(engine running)
P0251 INJECTION PUMP FUEL METERING CONTROL A. " pretty generic I'm told. But I am certain that's your trouble. Mines only done 96k. Keep getting told it's supermarket diesel and you must only use a genuine ford or Bosch fuel filter. Filter down to 2 microns. Non gen lets a bus through. Good luck pal. Oh get a leak off test done too. That'll tell you for sure.
Old Dec 13, 2013 | 07:29 PM
matti231074
Finally got the codes read, 1 for fault on injector 4, also on close listening we could hear a sort or pinging sound from that injector, tested with engine running, undid the supply to the injector and the noise went and the running sounded better, is it ok to replace injector 4 with this issue?,
Old Dec 13, 2013 | 07:34 PM
leep27's Avatar
leep27
I can't really answer that. Mine failed to start at all this week. No fuel pressure at crank over! Got No3 injector reconned. As No4 has already been done. 3&4 were the worst. It started immediately. But now missing and running shite. Dunno why. I put new code in. Bloody tdci's.
Old Dec 13, 2013 | 08:25 PM
matti231074
Sorry the code i got was as above the "metering control problem", can i replace the faulty one, as i ain't got alot of money, any help will be much appriaciated
Old Dec 13, 2013 | 08:33 PM
matti231074
Thanks for your reply leep97, i'm a little afraid of chucking money down the shitter, it's difficult to know what to do with this bag of shit, hope you get sorted soon
Old Dec 13, 2013 | 08:37 PM
GVK.'s Avatar
GVK.
Hundreds of threads on here relative to faults on these cars.
Search 'p0251'
Fordmad!
Sep 26, 2015 05:24 PM
Alun Gregory
Sep 6, 2015 09:40 AM
