S2 Running problem!!
when my car is hot only intermittently it will start idling very lumpy then gets worse very quickly.and just cuts out.then if i try to drive it judders and backfires!it will start again straight away but will cut out unless i hold the revs up.when i do this the fuel pump speeds up and slows down and the revs go up and down.if i leave the car for a while then it as if the problem never happened!any help appreciated guys, cheers.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
