fuel pump prob???
Old Mar 22, 2005 | 05:30 PM
cossiescott's Avatar
cossiescott
Default fuel pump prob???
my xr2 turbo wont start when its hot and been left for a while? starts fine from cold though? and it holds back at about 5000rpm under load?
Old Mar 22, 2005 | 06:05 PM
AKRS1's Avatar
AKRS1
when you say holds back at 5000rpm under load do you mean it misfires ? Could be injectors or fuel pump or the metering head
Old Mar 22, 2005 | 06:36 PM
cossiescott
it doesnt misfire it just wont rev past it?
Old Mar 22, 2005 | 06:45 PM
AKRS1's Avatar
AKRS1
just had this problem on my s2 changed nearly everything and after spending around £1000 it turned out to be the valve springs. Mine wouldnt pass 5000rpm either and it sounded like it was popping popcorn at 5000rpm dont know though if this could be the same problem has yours.
Old Mar 22, 2005 | 06:52 PM
cossiescott
ive just had a kent cvh37 cam put in and it comes with double valve springs and anti pump lifters so doubt its that! if i use light throttle it holds back lightly just before it comes up on boost 2?
Old Mar 22, 2005 | 07:55 PM
AKRS1's Avatar
AKRS1
could be fuel pump then rather than injectors
Old Mar 22, 2005 | 08:21 PM
DazC's Avatar
DazC
When was the last time you changed the fuel filter? Is the fuel pump ok?
Possible charge air temp sensor..
Old Mar 24, 2005 | 06:18 PM
cossiescott
rite guys it tryed it again today and when it comes up on boost in second it pulls hard till 5000pm then holds back if i change gear quickly and still using full throttle it wont pick up at all so am i rite in thinking maybe fuel volume isnt enough???
Old Mar 24, 2005 | 09:36 PM
DazC's Avatar
DazC
Dunno. It want's diagnosing properly to be honest.
Get it checked for fuel pressure and air to fuel ratio on a wide band lambda meter while on boost.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
