2wd saff shocks
Old Nov 1, 2013 | 06:44 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Default 2wd saff shocks
Just a quick question are there any differences in load/rebound between standard 2wd saff front shocks and 2wd cosworth front shocks, as I found some in the shed and was wondering if its worth the hassle fitting them now or just put up with the shit shocks till I get some konis
Old Nov 1, 2013 | 09:32 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
The damper height and rate its totally different i believe ginge. Give Doj a shout he will know....
I got a set of front konis with uprated std springs on that will be available soon. Ł100 plus postage.
Old Nov 1, 2013 | 10:08 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
uprated std springs?
ahha, is that like those male female humans?
Old Nov 1, 2013 | 10:13 PM
DixieTheKid
Pick-up P100 Power!
There is always one! Std ride height. You knew what i ment.
Old Nov 1, 2013 | 10:14 PM
Cossie Sean
its friday, what de ye expect
Old Nov 1, 2013 | 10:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
yes there is mate, can't be too sure on the exact specifics but the shocks are going to be just a little bit shorter and a little big better on the bump absorption
and seeing as there were 22 different front springs available for the sierra from the factory, you've got to be pretty sure that the dampers would have been suitably different as well
on the 4wd versions there were different between ac and non ac cars as well as left and rights so anything aftermarket won't have these subtle differences built in
Old Nov 2, 2013 | 07:32 AM
gingerturbo
Oh that's good as the front sits a little higher than the back so this should solve my problem for a while, it'll only be a temporary measure as standard shocks won't come with a boa weight/power
Old Nov 2, 2013 | 08:36 AM
dojj's Avatar
dojj
If you are sticking a v6 in the front they you will need specific v6 springs with v6 ratings, otherwise the extra lump if metal that you have under the bonnet will simply cause anything else use use to sag, regardless of if they are clause springs and updated or not
Old Nov 2, 2013 | 03:32 PM
gingerturbo
Oh ok so cossie springs will be no good then
Old Nov 2, 2013 | 07:01 PM
dojj's Avatar
dojj
it's a bit difficult but once you get your head around it it's fine
think of it this way:
the cossie spring has a higher poundage, but it's shorter, so the initial weight of the engine, which is much more, will compress the spring MORE and therefore your car will be much lower than it should be
the spring will also be designed to have x amount of load on it for cornering etc so it will compress at a certain rate, but you've already got too much weight on it so it won't handle properly either
imagine you go shopping and your plastic bag will carry one bag of potatoes, but you put in 2 bags of potatoes, the bag isn't designed for that sort of load so will be more likely to split
Old Nov 2, 2013 | 07:47 PM
DixieTheKid
Pick-up P100 Power!
just had a chat with my mate lee. he said you should be fine with cossie struts and springs.
His is in bits, it was supercharged...... wasnt enough! Hes going for compound charged the fucking nutter using a gt35!
Old Nov 2, 2013 | 08:15 PM
gingerturbo
Once the engines in and the bodyworks done I'm going for twin turbo
Ill work something out, ill pick up some xr4x4 springs
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
