Focus abs pump
Old Oct 28, 2013 | 01:44 PM
johnenright150rst's Avatar
johnenright150rst
Default Focus abs pump
I've got an 08 plate focus with the pump gone,
I have found another one with matching part numbers but can
Anyone tell me if it will need coding? And if yes who can code it
Regards john
Old Oct 28, 2013 | 02:11 PM
GVK.'s Avatar
GVK.
All depends what software is on the one you want to fit, which you wouldn't know until plugged into Ford IDS.
Anyone with Ford IDS should be able to code it.
Doesn't have to be a main dealer, some independents who do diagnostics on various cars may have an IDS set-up.
Old Oct 28, 2013 | 02:42 PM
johnenright150rst
Thanks for the reply,
So someone with a decent snap on scanner might be able to code it for me if it needs it then?
Old Oct 28, 2013 | 03:00 PM
GVK.'s Avatar
GVK.
I'm not aware of any other tools that can code modules other than Ford IDS as that's all I use.
(Other tools may be able to code the modules,but I have never used anything other than the proper Ford IDS tool)
Old Oct 28, 2013 | 03:36 PM
Ive changed loads of abs pumps on tranny connect vans and ive never coded them in or less these days its all to do with can bus system in these modern cars
Old Oct 28, 2013 | 04:08 PM
GVK.'s Avatar
GVK.
New or used modules? , can-bus has nothing to do with the software on the module, it's just a means of inter-module-communication.
Old Oct 28, 2013 | 04:14 PM
johnenright150rst
It's a second hand one I'm putting on as ford wanted 1300 and that's trade
So It sounds abit like pot luck regarding recoding then lol
Does anyone recon these units?
Old Oct 28, 2013 | 04:17 PM
Sometimes the pump/motor wears out and sometimes its the module. The module just screw to the back of the pump/motor.
Old Oct 28, 2013 | 04:18 PM
Or well I thought it might have something to do with it.
Old Oct 28, 2013 | 08:56 PM
GVK.'s Avatar
GVK.
What fault has it got? If it's the common brake pressure sensor as per many MK60 ABS pumps, people like BBA reman and other ECU repairers can repair them.
http://www.bba-reman.com/index.aspx
http://www.ecutesting.com/ford_focus...s_pump_mo.html
This ABS Pump Module is a very common failure for the Ford Focus & C-Max vehicles built between 2004 - 2008. The fault causes the ESP light to illuminate permanently on the instrument cluster.
If you have been for a diagnostic check on your Ford then your mechanic will probably have told you that your have a fault with your “Brake Pressure sensor” or given you the full fault code of: “C1288 PRESSURE TRANSDUCER MAIN/PRIMARY CIRCUIT FAILURE” and will probably have told you that you must change your ABS Pump Module for a small fortune
The main dealer is currently charging over one thousand pounds plus fitting for a replacement ABS pump module.
When we rebuild your ABS pump we not only correct the problem but the materials and processes we use will reinforce your ABS pump module to prevent the fault from ever reoccurring.
Old Oct 29, 2013 | 04:53 PM
johnenright150rst
Cheers did try and ring them a few times but couldn't get hold of them.
Bought one off eBay now so will hopefully sort the problem, the cars being sold and want everything 100% as I haven't got it in me to rip Someone off with a bodged up car.
Cheers for the replys and info much appreciated
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
Sep 3, 2015 10:49 AM
