Celica gt4 help!
Hey just purchased a gt4 on a n reg!
It has only done 72000 kilometres as has been garaged for the last 4 years, it completely standard.
I have no clu whts what with these,
It's a 205
Does anyone no if these have external waste gates?
Also if so how does a screamer pipe fit onto this?
I've ordered a few gadgets for her and wana get her ney ney ney ney ney like a horse ( pigeon sound) coming off the throttle,
Any ideas?
It's a 205
Any ideas?
they dont have external wastagetes as standard!
i need engine pics please
although these are charge cooled, and have very complicated front suspension and are a cunt to work on.
looked after a few from standard cars to a gpA Castrol ST205
Lovely stuff, does the turbo need to be externally gated in order to fit a screamer pipe?
What is the standard bhp of the gt4?
I'm in pitsea mate
Ill upload pics this week as she is geting serviced and motd
Took her into the garage today don't have any pics atm!
I'm in pitsea mate
Haha, I understand
Yeh I pic her up hopefully Sunday Monday
Ill give you a whistle pal n pop round n u can have a butchers n let me no what's what.
Only paid 2k for her
Cheers Sean
Cheers Sean
It's a 205
Any ideas?
It's a 205
Any ideas?
The noise you seek would generally be heard when there is no dump valve fitted.
However as that car has a very very fragile turbo, it would be rather foolish to even contemplate removing the dump valve, unless you're also budgeting for turbo repairs or replacement.
Another 205 owner here mines a wrc so has all that anti lag bollox on manifold if that makes any difference the noise you are reffering to is compressor stall when you let of throttle pressurised air is forced backwards though the compressor housing a dump valve prevents this by releasing excess pressure, mine still neighs abit but mine is not realy standard engine wise, also check your front suspension for wear there excelent when well maintained but expensive when not, i know of some st205s being broke if theres anything your after
Lol
Hey fez,
If the turbos aren't that great on these, which turbo would u recommend replacing it with, I want serious power lol well at least 330 , also a screamer pipe,
The front suspension is solid there is no rust or rot at all over the hole car, no leaks and the engine is clean without any grease or crack stuck to it,
Hey fez,
Mike Rainbird
Aug 3, 2004 12:45 AM
