Few pics of my poor car lol
I'm guessing a rod let go on the way back from the last breakfast at goodwood a few weeks ago. Started to take her apart so I can get a clear idea of what I'm going to need to build a new engine
Is that a big hole in the block?Or is it just oil cause the pic isnt very clear.
No it's not a big hole it's a massive hole lol
I'm 99% sure it's scrap my new block will have liners.
Head looks ok ill drop the valves out tomorrow fingers crossed the crank is ok
Jesus that must have been a Big Bang... Did it happen under full boost?
You would be lucky to hear yourself think in it with my exhaust and gearbox lol.
But no mate not really was chatting to my bro herd abit of a funny noise and it miss fired and lost power started to smoke so I switched it off and costed to a lay by
So what causes something like this to happen then Andy??
And what next then pal?? Bigger and more power I'm guessing
Hard to say till the block is stripped iver the rod or piston broke up!
Iver way the rod has pushed the piston to the top of the bore against the head then slipped to one side and gone through the bore!
I will build a new bottom end / head with 650bhp in mind then put it back together as it was to run it in. Then change the turbo and exhaust manifold and go for some power
Yes but a long road I'd also have to do a 3.5 inch exhaust system/down pipe mod my fly wheel fit a small basket twin plate ap clutch and hydrolic conversion and would won't a 6 degree rear beam and supra diff!
I'm in no rush it's not going any wear I'd like to think it will be driving by this time next year the latest
I said in the reply to your last post bud.
Most likely rod broke pushed piston to top of bore then slipped to one side of the piston and through the bore. I'll say for sure when the bottom half is stripped
It's just one of them things
I have 2 options for blocks a I've a friend who has a number of them including an rs500 one. He also has a mountune wrc block I can have for 800 but he is a bit of a helmet lol he also has a number of standard grind cranks for 400.
Or I can get a block from opplinger his are 650 iver way it will get iron liners fitted be long studded and have oil spray jets fitted
Yes mate it's hard to get him to sell stuff lol he has 7 standard grind cranks a new rs500 block! And a number of other 200 blocks! He got a job load of bits from oakfields
I went up there the other week I see the stuff mate he has so much money's worth of parts kicking around it's un real.
He opened his locker and there was 7 cranks in there all baged up with paper work from being checked over! I see the mountune and rs500 block as well and he had a new set of longer arrow rods it's crazy the money he must in bits fuck knows why he don't just sell it all pile of sumps loads of rocker covers big wing sumps all sorts
