Bit of an engine problem! Blocks apart
Old 24-10-2013, 03:16 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Default Bit of an engine problem! Blocks apart
Few pics of my poor car lol
I'm guessing a rod let go on the way back from the last breakfast at goodwood a few weeks ago. Started to take her apart so I can get a clear idea of what I'm going to need to build a new engine
Old 24-10-2013, 03:23 PM
Is that a big hole in the block?Or is it just oil cause the pic isnt very clear.
Old 24-10-2013, 03:29 PM
ajamesc
ajamesc's Avatar
No it's not a big hole it's a massive hole lol
I'm 99% sure it's scrap my new block will have liners.
Head looks ok ill drop the valves out tomorrow fingers crossed the crank is ok
Old 24-10-2013, 03:34 PM
james kiely
james kiely's Avatar
ooh that let go big time mate
was you giving it stick up in the rev range ?
Old 24-10-2013, 03:35 PM
lee2cossies
lee2cossies's Avatar
Is it me or does the block look to have liners in it anyway? Something big gone wrong there for that too happen!
Old 24-10-2013, 03:37 PM
ajamesc
ajamesc's Avatar
Not hugely mate just one of them things and a bit of my luck I guess lol
Old 24-10-2013, 04:11 PM
Ebonycossie4x4
Ebonycossie4x4's Avatar
Jesus that must have been a Big Bang... Did it happen under full boost?
Old 24-10-2013, 04:13 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
200 blocks ain't all that then lol
Sorry to see this
I hope it had a worth while death like the 4i did
Steve
Old 24-10-2013, 04:14 PM
ajamesc
ajamesc's Avatar
You would be lucky to hear yourself think in it with my exhaust and gearbox lol.
But no mate not really was chatting to my bro herd abit of a funny noise and it miss fired and lost power started to smoke so I switched it off and costed to a lay by
Old 24-10-2013, 04:16 PM
ajamesc
ajamesc's Avatar
Sorry to see this
Steve
Ha ha not many blocks will argue with a un attached con rod smashing round mate! Still on wards and up wards I'll 650 it now
Old 24-10-2013, 04:29 PM
gjh
gjh's Avatar
Must of been a bang and a half! Fuck, it, go for a monster power build now, best excuse for one ever.
Old 24-10-2013, 04:30 PM
Staffi
Staffi's Avatar
So what causes something like this to happen then Andy??
And what next then pal?? Bigger and more power I'm guessing
ajamesc
ajamesc's Avatar
I'm going too
Old 24-10-2013, 04:32 PM
gjh
gjh's Avatar
Good lad!
andy130
andy130's Avatar
What spec was the engine before hand james?
Old 24-10-2013, 04:35 PM
ajamesc
ajamesc's Avatar
Hard to say till the block is stripped iver the rod or piston broke up!
Iver way the rod has pushed the piston to the top of the bore against the head then slipped to one side and gone through the bore!
I will build a new bottom end / head with 650bhp in mind then put it back together as it was to run it in. Then change the turbo and exhaust manifold and go for some power
Old 24-10-2013, 04:37 PM
ajamesc
ajamesc's Avatar
It had an m.a.d 500bhp set up
Old 24-10-2013, 04:38 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
Good too see your gonna soldier on with it
would like to find out the cause of the rod failure, not seen one that high up on a YB personally.
hope the head is all good minus the valves/guides ofcourse
Sean
Edit, typed while the 2 above posts appeared
Old 24-10-2013, 04:40 PM
ajamesc
ajamesc's Avatar
Sean
at the mo the head looks ok ill drop the valves out tomorrow and get a good look at it
Old 24-10-2013, 05:10 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Bloody hell mate thats a mess, on a plus side the oil will stop the underside going rusty lol
Steve
Old 24-10-2013, 05:12 PM
ajamesc
ajamesc's Avatar
Steve
Just spent 3 grand having the underside done new iner and outer sills and the odd bit here and there lol
Old 24-10-2013, 05:19 PM
LHD220Turbo
LHD220Turbo's Avatar
Not good Andy; i blame Chris for being in the car with you!
perfect excuse to go for more horses though, what turbo you going for?
Old 24-10-2013, 05:21 PM
ajamesc
ajamesc's Avatar
Early days yet but I'll hope to take the twin scroll Borg route
Old 24-10-2013, 05:25 PM
LHD220Turbo
650hp will be a beast!
Old 24-10-2013, 05:29 PM
ajamesc
ajamesc's Avatar
Yes but a long road I'd also have to do a 3.5 inch exhaust system/down pipe mod my fly wheel fit a small basket twin plate ap clutch and hydrolic conversion and would won't a 6 degree rear beam and supra diff!
I'm in no rush it's not going any wear I'd like to think it will be driving by this time next year the latest
Old 24-10-2013, 05:40 PM
Staffi
Staffi's Avatar
So can someone tell me, what has caused it
Old 24-10-2013, 05:43 PM
ajamesc
ajamesc's Avatar
I said in the reply to your last post bud.
Most likely rod broke pushed piston to top of bore then slipped to one side of the piston and through the bore. I'll say for sure when the bottom half is stripped
It's just one of them things
Old 24-10-2013, 06:02 PM
Staffi
Staffi's Avatar
Oh sorry Andy, it's my age I'll give myself one of these
Old 24-10-2013, 06:08 PM
scoooby slayer
scoooby slayer's Avatar
any block will do that with a broken rod ive seen a 3306 cat block just like that, I could fist it lol
is it time for 600+ hp then now ?
Old 24-10-2013, 06:09 PM
KSA-Cossie
KSA-Cossie's Avatar
Becoming a habit that Pete !!
Old 24-10-2013, 06:11 PM
Staffi
Staffi's Avatar
Sure is Bruv
You'll get it too
Old 24-10-2013, 06:25 PM
Moonstone Steve.
This would sort you out Andy
http://mt-motorsport.com/marko/index...oducts_id=1573
Steve
Old 24-10-2013, 06:29 PM
ajamesc
ajamesc's Avatar
I have 2 options for blocks a I've a friend who has a number of them including an rs500 one. He also has a mountune wrc block I can have for 800 but he is a bit of a helmet lol he also has a number of standard grind cranks for 400.
Or I can get a block from opplinger his are 650 iver way it will get iron liners fitted be long studded and have oil spray jets fitted
Old 24-10-2013, 06:31 PM
Jay,
Sponsor
Jay,'s Avatar
Sure is Bruv
You'll get it too
No he wont youve been soppy ever since ive known you
Old 24-10-2013, 06:32 PM
Jay,
Sponsor
Jay,'s Avatar
I that fuller by anychance
Old 24-10-2013, 06:37 PM
ajamesc
ajamesc's Avatar
Yes mate it's hard to get him to sell stuff lol he has 7 standard grind cranks a new rs500 block! And a number of other 200 blocks! He got a job load of bits from oakfields
Old 24-10-2013, 06:38 PM
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
Wow what a hole
Old 24-10-2013, 06:39 PM
Jay,
Sponsor
Jay,'s Avatar
Yes he did say i ask for stuff but never see it
ajamesc
ajamesc's Avatar
Yes it will go back together with more power but maybe after being ran in as it was! But every thing will be built with 650 in mind is the plan
Old 24-10-2013, 09:18 PM
ajamesc
ajamesc's Avatar
I went up there the other week I see the stuff mate he has so much money's worth of parts kicking around it's un real.
He opened his locker and there was 7 cranks in there all baged up with paper work from being checked over! I see the mountune and rs500 block as well and he had a new set of longer arrow rods it's crazy the money he must in bits fuck knows why he don't just sell it all pile of sumps loads of rocker covers big wing sumps all sorts
Quick Reply: Bit of an engine problem! Blocks apart
