Fuel Pumps
Old Oct 20, 2013 | 01:52 AM
TMitch's Avatar
TMitch
grease monkey
Default Fuel Pumps
Hey Everyone,
How many LPH is the Sierra Cosworth's fuel pump? Do most guys put in a higher flow fuel pump even while running stock for future power builds?
Thanks
TMitch
Old Oct 20, 2013 | 07:28 AM
opposite lock's Avatar
opposite lock
The cosworth pump bosch 941 according to Burtons is 3.67Lper minute. Its sufficent over and above standard power but many choose the 044 pump for big power.
Old Oct 20, 2013 | 08:39 AM
Brendan's Avatar
Brendan
struggling with reality
as above.... the 044 has earned its reputation! fit and forget!
Old Oct 20, 2013 | 10:03 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you need to change the pump, get the best one you can afford.
i opted for a 913 pump, which is basically a 044 pump, but hand built with some better parts, rated to run at 8BAR and peak at 10BAR, you need to be in motorsport to get hold of one though.
what i'm saying is, future proof when you can.
Old Oct 20, 2013 | 09:04 PM
TMitch's Avatar
TMitch
grease monkey
I have a friend who owns a tuning shop and he has some connections I will look for future proofing. Either that or Walbro 255LPH pump.
Thanks boys
Old Oct 21, 2013 | 08:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
more than tuning to get a 913, it has to be a motorsport team as bosch do not deal with anyone else on these, rrp is somewhere like Ł349 IIRC.
an 044 in standard form will do most peoples applications, i just got offered mine cheap at the time.
Old Oct 22, 2013 | 12:21 PM
martysmartie's Avatar
martysmartie
More than enough for the 'average' tune.
It's a different story in the case of an Escos though, which uses a pump which can be found in a Orion .
Martin
Old Oct 29, 2013 | 07:29 PM
TMitch's Avatar
TMitch
grease monkey
Does the Sierra Cosworth have an intank and body mounted fuel pump just like the Merkur's
Old Oct 30, 2013 | 12:07 PM
opposite lock
External fuel pump.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
