el. boost control question
Old Oct 18, 2013 | 10:57 AM
1cosworth's Avatar
1cosworth
Default el. boost control question
question for those with an electronic backround. ive seen that firms use the mac 35a 3 port valve in their boost control appications. can i use the same valve with a simple potentiometer or voltage regulator to adjust the opening of the valve . other any ideas about diy el.boost controlers?
Old Oct 19, 2013 | 01:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No mate, BCS are normally PWM like an ICV.... The negative/earth is pulsed, faster the pulse the more it opens.
Old Oct 19, 2013 | 06:44 PM
1cosworth's Avatar
1cosworth
thanks for the reply karlos, so to get this straight there is nothing cheapish i can do to use the valve as a boost regulator?
Old Oct 19, 2013 | 09:26 PM
stevieturbo's Avatar
stevieturbo
C**t
Yes. Buy a cheap boost controller, or use your ecu to control it ( presuming you have an ecu that can )
A better question might be, what exactly are you trying to do ?
If you want cheap, just use a mechanical bleed valve.
Old Oct 20, 2013 | 07:42 PM
1cosworth's Avatar
1cosworth
stevie i do have mech. bleed valve but i was trying for something more accurate and cheap. i guess i ll stick with this for now thanks!!
Old Oct 20, 2013 | 07:57 PM
stevieturbo
C**t
A mechanical bleed valve in conjunction with a sensible actuator, is still a pretty effective option.
And accurate compared to what ?
Are you experiencing a problem with the boost ?
Old Oct 21, 2013 | 08:02 AM
1cosworth's Avatar
1cosworth
it wont hold the boost still at 15psi lets say ,for long time. usually after 15 -20 days it boosts a bit higher 20psi and i need to adjust it again
Old Oct 21, 2013 | 09:06 AM
stevieturbo
C**t
And what actuator are you trying to use ?
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
