Hi lads and girls, I am going to put a direct feed from ignition to an inline fuse then to a rocker switch then straight to my fuel pump, then earth it to the body, my question is what ampage wire should I use including fuse and rocker switch ? for my RST S2
Why do you want to run the pump off a rocker switch ? Why not just have it activated by the original fuel pump trigger ?
This what last owner was going to do, I think the relay system is no good, it just means I prime the system with a switch then on start up flick it back on again.
John
