Fuel pump wont work??????
Old Oct 11, 2013 | 05:25 PM
Lee Grout's Avatar
Lee Grout
Default Fuel pump wont work??????
Right, my car is a project so is off the road. Only start it every so often to bring it upto the house, work on it then back into the garage.
One day had the car upto the house and worked on it. Came the time to put it away and it wouldnt start! Yes battery was absolutely fine, but cant now hear the fuel pump prime!
Got a replacement off a guy near me, he tested it and said it defo worked ok. Got the tank down and plugged the pump in. Tried the ignition before re fitting ( dont want to have to take it down.......again!) Didnt work! 2 small nicks in the wires to the plug so i cut them and re-joined them and still nothing! Fuse is ok and I can also hear the relay click when I turn the ignition on but the pump wont prime!
Any ideas please. Im really not good with car electrics unless its wiring up a stereo!!
Old Oct 11, 2013 | 06:15 PM
Nick 172 Sport's Avatar
Nick 172 Sport
it would help if we knew what car it is
Old Oct 11, 2013 | 06:23 PM
adam151082's Avatar
adam151082
If its a Cosworth there as good chance its the wiring loom, new fuel pump looms can be bought for Ł50ish
Lee Grout's Avatar
Lee Grout
Sorry, escort mk6 1.6
Old Oct 11, 2013 | 06:24 PM
Lee Grout's Avatar
Lee Grout
Originally Posted by adam151082
If its a Cosworth .......
lol I wish!
Back to the top!
Old Oct 12, 2013 | 08:49 PM
Lee Grout's Avatar
Lee Grout
Anyone??
Old Oct 12, 2013 | 08:58 PM
TOOTALL's Avatar
TOOTALL
I wish my neighbours would work.
Old Oct 12, 2013 | 09:01 PM
Lee Grout's Avatar
Lee Grout
lol at the........' light entertainment' !
Old Oct 12, 2013 | 09:06 PM
TOOTALL's Avatar
TOOTALL
Keeping it bumped sir.
Old Oct 12, 2013 | 09:20 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Check that the inertia switch hasn't been knocked.
Old Oct 12, 2013 | 09:33 PM
st3v3's Avatar
st3v3
or if there is one, the relay is good and not playing up.
Old Oct 12, 2013 | 10:06 PM
RichieST's Avatar
RichieST
Have you checked there is power at the pump?
Old Oct 12, 2013 | 10:11 PM
jamie's's Avatar
jamie's
what he said
Old Oct 13, 2013 | 05:40 PM
Brendan's Avatar
Brendan
struggling with reality
check the "crash" switch, then using a DVM check for 12v plus on the power wire and then check the other (ground) wire for continuity with the chassis! If you have problems PM me and if desperate I can skype you and talk you through it!
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
