3dr cosworth electricial experts please
Just finished building a 3dr drift project , it's yb powered and not running cleanly.
I don't seem to have a great spark at number four as if I unplug four spark plug I don't get a note change and the disb cap earths /sparks to the inlet manifold,
All other cylinders drop note when unplugged but also hear a clicking sound from dist cap ??
I unplugged the dist multiplug and when I plug it back in the std fuel press reg opens/activates (strange one)on the fuel rail
I changed to a new cap and just swapped over five leads and cap from my running cosworth to double check ??? SAME
Help........
Help........
Swapped plugs to no avai but the switching of the fuel pressure reg when disconnecting the dist plug has me thinking it more complicated than that....
surely it's 2 separate issues
the lack of spark/poor running at 4 can only come from the dizzy cap to the plug or a lack of compression /cylinder issue at no 4 as your fpr issue would effect all cylinders
I'm not sure about the FPR issue
steve
steve
Youth
Changed cap,leads from my running saff and no difference, fuel pressure set at 2.5/3.0
Must just check for four teeth on front pulley and then distrib ???
Comp checked at 120 on all four (good/bad???)
Im not sure exactly what you mean with the fpr 'issue'
the fpr opens when the fuel inside the rail reaches a certain pressure. If its clicking are you sure you arent turning the pump on and off when you are messing with the wiring?
If I have eng off,ign on and I disconnect the dist multiplug the fpr opens/clicks , strange one !!
Doesn't happen on my saff
Still haven't got someone to verify this is wrong /suspect
The annoying ginger guy
The worm gear could be fine but there could be movement in the distributor shaft then the air gap between the rotor arm and point4 on the cap could be increased?
Check for movement first, also get someone to turn the engine over with cap off and see if if the shaft is spinning dead centre and not bent in any way
Just thinking the rail will always be at full pressure while igns on afaik as pressure will be maintained by pump to set pressure
Any chance dist plug is swapped with another , for example the iscv....
They won't reach but had loom checked and he wrapped in new oem tape and maybe same length leads and they got mixed up...
Just went out to check lugs on crankshaft wheel and all four in place but FFS , to answer a question above I thought I'd check if disconnecting the dist multiplug would fire the fuel pump , and yes it does......but I wiggled the loom and found if I disconnect or wiggle the crankshaft sensor I also fire the fuel pump which results in the clicking I mentioned earlier on the fpr (valve opening releasing pressure back to tank),,,,,,,
Bloody Nora
Bloody Nora
Clearly the problem lies with a mechanical problem on that cylinder!
Compression does not really tell you much as there may be a bad valve clearance, for example.
The FPR is a totally mechanical affair, it's more likely what you are hearing is the injectors 'pulsing' with you plug the PHASE sensor back in.
When the ignition is on the fuel pump does not run (unless you have changed the standard setup)
Martin
Martin
make sure you have a 0.6-1mm gap on the crank pick up sensor
David
you cannot see the pulses to the injectors with a meter you need a void light
phase sensor sends a signal back to tell the ecu which pulse from the crank pulley is tdc and 90 degrees btdc (sort of reminding it where the engine is for ign timing)
David
David
Martin
