Does a remap need afr checking?
Old Sep 28, 2013 | 09:49 PM
saph4be's Avatar
saph4be
Default Does a remap need afr checking?
Been looking at getting a remap on my vxr and I'm being told all sorts! Biggest worrie is that it should be done on a rolling road to check afr ect? Should I be looking into this or are most cars safe at the optimized file?
Old Sep 28, 2013 | 09:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I would always want my AFR checking with any remap.
Steve
Old Sep 28, 2013 | 10:32 PM
RS Grant's Avatar
RS Grant
Made in Scotland
As above, I'd be very worried if a tuner wasnt checking AFR when tuning a car. Plus, just so you know, it doesn't need to be done on a rolling road either... can be checked on open road too.
Cheers,
Grant
Old Sep 28, 2013 | 11:11 PM
LHD220Turbo's Avatar
LHD220Turbo
its not worth guessing the afr is correct, if its a generic off the shelf map then i wouldnt get it done unless the afr's are checked
what if your car has a problem which you're unaware of?
Old Sep 28, 2013 | 11:19 PM
GVK.'s Avatar
GVK.
Obviously it's advisable that it is checked but I bet there are hundreds of cars remapped at your home/work place by mobile installers that aren't...
Old Sep 28, 2013 | 11:48 PM
scoooby slayer's Avatar
scoooby slayer
the problem is if theres an issue they don't know about that is no problem with a stock car it may become a problem once the map is tweeked/boost increased etc.
id want it checking, tbh the first thing I do on any turbo car I buy is fit an aem afr gauge for £130 its not worth the risk imo.
Old Sep 29, 2013 | 07:19 AM
saph4be's Avatar
saph4be
That's what I thought I asked a few local company's and seems they deem it not needed at this level?
Old Sep 29, 2013 | 11:44 AM
GVK.'s Avatar
GVK.
Might be worth asking Stu @ motorsport developments what his installers do.
On the couple of occasions I've seen VWs get remapped (loading a pre-tuned flash) by Revo and AmD all they did was road test with vag-com/vcds showing live data. When main dealers do cal updates from the manufacturers they aren't AFR checked either.
Obviously if you're building a cal from scratch that's a different kettle of fish altogether.
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
dojj
Sep 29, 2015 10:32 PM
Sp3no
Sep 27, 2015 07:23 PM
