Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
1.8 tdci motorway problem
Old Sep 24, 2013 | 11:50 AM
Ian Cliff's Avatar
Ian Cliff
Default 1.8 tdci motorway problem
I wonder if someone can help, after doing a longish run on the motorway 20 plus miles, when you get off at the slip road my engine stalls and will not start again till its cooled a little (10 mins or so) it can be very uncomfortable as its happened 4 or 5 times now and its been very busy so im stuck on a very busy slip road and roundabout, do you think its some sort of sensor over heating or something else?
other than this the car seems fine just seems to stall after a long constant run
oh and its a 56 reg 1.8 tdci.
thanks Ian
Old Sep 25, 2013 | 09:37 AM
uruk hai's Avatar
uruk hai
It could be a few things but assuming the car is well maintained I would be looking at the cam shaft position sensor as it "could" be that and it doesn't cost a fortune to change?
Old Sep 25, 2013 | 11:38 AM
Ian Cliff's Avatar
Ian Cliff
thanks for the info yes its well looked after it was only serviced last week, so it should be on top form, ill look int the cam shaft sensor as you say
Old Sep 25, 2013 | 12:08 PM
FlashRS's Avatar
FlashRS
What car is it? Does the glow plug light flash at all? Did they change fuel filter at service?
Old Sep 25, 2013 | 03:40 PM
Ian Cliff's Avatar
Ian Cliff
Its a 56 reg tdci sport estate, the fuel filter was changed at the last service, do you mean the glow plug light flashes when it stalls or any time, the answer the same anyway it seems to be working as it should no flashing at all just come on when the key is inserted then goes off after 5 seconds or so
Old Sep 25, 2013 | 05:31 PM
GVK.'s Avatar
GVK.
Like anything the first port of call is to get the fault codes read before randomly replacing parts willy nilly.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
talon1
Sep 15, 2015 10:27 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
