Oil leak
Old Sep 20, 2013 | 07:18 AM
Fordmad!'s Avatar
Fordmad!
Default Oil leak
Have quite a bad oil leak on my 3i
Its coming from where the box attaches to the engine.
Is it the crank seal?
Old Sep 20, 2013 | 07:44 AM
Ben26's Avatar
Ben26
Give it a really good clean mate and try and see exactly where it is comin from.
If not drain the oil and drop and re seal the sump . I would do this before ripping the box out and doing the crank seal.
Old Sep 20, 2013 | 07:49 AM
Fordmad!'s Avatar
Fordmad!
Its definatly not the sump.
Just had the head rebuilt and the lad doing it said something about the leak coming from the crank and taking the box off i cant remember exactly what he said thought but sure he mentioned the crank seal
Old Sep 20, 2013 | 08:43 AM
It could be the crank shaft oil seal.Or less its leaking from the sump.Arnt these sump gaskets a nightmare to get right so they dont leak.
Old Sep 20, 2013 | 09:07 AM
Fordmad!'s Avatar
Fordmad!
100% not the sump gasket
Old Sep 20, 2013 | 09:08 AM
Rear cranks shaft oil seal then.Gearbox clutch and flywheel off time.
Old Sep 20, 2013 | 09:10 AM
Fordmad!'s Avatar
Fordmad!
Thats the one
Old Sep 21, 2013 | 09:30 AM
Ben26's Avatar
Ben26
Best get busy then mate. Lol. Weathers alright this weekend.
Old Sep 21, 2013 | 02:32 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
You should be able to do that in a hour or so, does sound like the rear main seal
Old Sep 23, 2013 | 11:53 AM
mac_chanic's Avatar
mac_chanic
Rear seal? There is an oil seal at the rear of your engine near the transmission. I think that one is difficult and expensive. Do you see blue smoke coming from the underside of the car?
Old Sep 23, 2013 | 03:41 PM
Fordmad!'s Avatar
Fordmad!
The seal is only £8 its just the ballache of getting the box off
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
