What bhp should I get
Old Sep 15, 2013 | 02:34 PM
foci18's Avatar
foci18
Default What bhp should I get
Just wondering what bhp I should be getting out of a s2 it's still on mfi bit got oversized pistons, piper cam and pulley, pace intercooler, air filter, chipped ecu, set at about 12-15 psi
Old Sep 15, 2013 | 02:37 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
170-180ish
Old Sep 15, 2013 | 02:40 PM
foci18's Avatar
foci18
Seems like about 140 is doesn't pull like it used to had it setup 2 months ago and now just feels under powered I might change the actuator to a -31 cause it doesn't hold boost as strong
Old Sep 15, 2013 | 02:42 PM
rsmark86's Avatar
rsmark86
If you got it set up to around 17/18psi it should pull 190bhp ish which I find drives lovely
But all depends on your metering unit as they are all different and which valve springs are fitted, as piper ones are useless
Old Sep 15, 2013 | 02:44 PM
rsmark86's Avatar
rsmark86
On a cvh actuators are like service parts lol, every car I've took to be set up has needed one, so I always fit a new one before a tune up
Old Sep 15, 2013 | 02:52 PM
foci18's Avatar
foci18
Thanks for the advice will get a new one and couldn't tell you what springs brought the engine complete and dropped It in metering head is in good nick according to the tuner what springs would you recommend and where to get them from
Old Sep 15, 2013 | 02:54 PM
Adam.'s Avatar
Adam.
Agreed had to fit a 34 as my 31 wasnt upto the job when i was recently on the rollers, and the 31 was fitted at the setup beforehand a year earlier lol.
Old Sep 15, 2013 | 03:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's the turbo thats your limiting factor (assuming it's stock), so 190bhp max, but at 12-15psi your looking at 150-170.
Old Sep 15, 2013 | 04:01 PM
foci18's Avatar
foci18
Cheers guys will get a new actuator and get it setup again hopefully it will be closer to 170-180 bhp
Old Sep 16, 2013 | 12:39 AM
rsmark86's Avatar
rsmark86
genuine ford springs or decent doubles from newman ect
there seems to be no other alternative thats actually works
at your power level even the poor ones should be ok and is worth a go
if its being set up, rather than saying to the tuner "i want 12-15psi" say to him set it up to the best it can be with its condition and spec
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
