What bhp should I get
Just wondering what bhp I should be getting out of a s2 it's still on mfi bit got oversized pistons, piper cam and pulley, pace intercooler, air filter, chipped ecu, set at about 12-15 psi
Seems like about 140 is doesn't pull like it used to had it setup 2 months ago and now just feels under powered I might change the actuator to a -31 cause it doesn't hold boost as strong
Thanks for the advice will get a new one and couldn't tell you what springs brought the engine complete and dropped It in metering head is in good nick according to the tuner what springs would you recommend and where to get them from
Needs Beer Tokens.....
Agreed had to fit a 34 as my 31 wasnt upto the job when i was recently on the rollers, and the 31 was fitted at the setup beforehand a year earlier lol.
genuine ford springs or decent doubles from newman ect
there seems to be no other alternative thats actually works
at your power level even the poor ones should be ok and is worth a go
if its being set up, rather than saying to the tuner "i want 12-15psi" say to him set it up to the best it can be with its condition and spec
