Mtx again
Old Sep 10, 2013 | 07:21 PM
little bram's Avatar
little bram
Default Mtx again
Been messing about looking into fitting mtx box. got it bolted up to the engine marked it up so I know where to trim the chassis leg.
how do people go about measure for drive shafts. ive got a idea but just want to see how everyone else would go about it.
also ave got a cosworth clutch drive plate if I get a cover will it work?
thanks
lee
Old Sep 10, 2013 | 08:05 PM
studabear's Avatar
studabear
Do you think the inner wing could be persuaded with a hammer for clearance of a mtx box ?
Old Sep 10, 2013 | 08:15 PM
little bram
ha mite work mate there's no much in it
Old Sep 10, 2013 | 09:00 PM
studabear's Avatar
studabear
What car is the mtx your using from?
Also drop crazycage a pm regarding shafts, he should be able to advise you well
Old Sep 10, 2013 | 09:01 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
when i made my shafts i used focus rs shafts and mk2 xr2 shafts i cut all 4 shafts up and used the focus rs inner halfs and the xr2 outer. i measured the width of the 4 half's and had some sleeves made up (crazycage made them for me)
fitted all the bits and sat the car flat on the floor i moved the bits around untill i felt the inner and outer were sitting in the right place.
i then spot welded it stripped it all down welded it all up and refitted it all i then drove the car around on welded shafts for a week or so just to make sure all was good.
i then had the welded shafts copyed and made into one piece shafts
just to add tho the welded shafts took 1bar boost from a gt30 for ages. and the one piece shafts went on to snapping lol
Old Sep 10, 2013 | 09:03 PM
clarke5700's Avatar
clarke5700
as seen hear lol
Old Sep 12, 2013 | 08:42 PM
little bram
Its out of a mondeo mate
Ive pm'd craycage but he didn't get back to me.
thanks anyway mate
Old Sep 12, 2013 | 08:50 PM
studabear's Avatar
studabear
he's pretty busy, can take a while at times
Old Sep 12, 2013 | 08:54 PM
little bram
Thanks mate ave got the mondeo shaft's so going to cut them up. il try and some sleeves made, the part I was thinking about was how far to put the shaft in the inner cv joint.
Old Sep 12, 2013 | 08:56 PM
studabear's Avatar
studabear
In the middle at a guess.
Old Sep 12, 2013 | 08:57 PM
little bram
yeah mate I was thinking that there seems to be a lot of people getting things made by him
Old Sep 12, 2013 | 09:13 PM
little bram
Well was thinking with the car sitting on the floor with the shaft level i would think it would be at its shoties so the shaft should be sitting canny far in.
Old Sep 12, 2013 | 10:05 PM
studabear's Avatar
studabear
with the car a ramp weight on suspension a lock to lock check might help
Old Sep 13, 2013 | 07:32 PM
crazycage's Avatar
crazycage
sorry bram , I did get your pm but got side tracked ,I get loads of pm's every day and it takes me ages to work my way through them .
don't bother with the cossie clutch ive yet to see one work properly on a zetec.
Old Sep 13, 2013 | 09:36 PM
little bram
No problem mate I gest you would have. What's the problem with the cosworth clutch does cover fit? Ave got a helix 6 paddle drive plate and it fits the flywheel and splins in the box but I haven't got a cosworth cover and the standard mondeo one won't cover the paddle plate.
Old Sep 15, 2013 | 12:51 PM
crazycage's Avatar
crazycage
[QUOTE=little bram;6329263]No problem mate I gest you would have. What's the problem with the cosworth clutch does cover fit? Ave got a helix 6 paddle drive plate and it fits the flywheel and splins in the box but I haven't got a cosworth cover and the standard mondeo one won't cover the paddle plate.[QUOTE
Not sure mate I've never tried fitting one mate .I no a few people that couldn't get them to hold good power
neil18
Mar 14, 2016 01:08 PM
massivewangers
30
Oct 1, 2015 07:40 PM
cossirob
Sep 16, 2015 07:39 PM
MK5RST
Nov 14, 2004 09:06 PM
