Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Ignition barrel problem!
Old Sep 2, 2013 | 10:31 PM
dousetheflames's Avatar
dousetheflames
Default Ignition barrel problem!
Hi All,
this is my first posting here so here go's.
I have just bought a 2003 Focus 1.6 Zetec LX, when I turn the ignition key from position II to position III the engine starts fine but the key does not 'flick back' to position II, I have purchased a new barrel but after trying to turn the keys in it before fitting into the car find that they turn freely as well with no return to position II.
I inquired at my local Ford dealers and they told me that the key spring return part was build into the ignition/steering column, replacement cost £585!
Is this correct or is there another part with the 'spring' part in?
Thank you anyone for your help.
Richard
Old Sep 3, 2013 | 10:53 AM
GVK.'s Avatar
GVK.
Yes, that's correct, the spring is in the barrel housing.
Get a second hand column from a breakers, loads of mk1 Focus being crapped/broken now.
Daniel Howard
17
Sep 26, 2015 12:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
marky_g
Sep 12, 2015 04:26 PM
