bright green liquid
Old Aug 26, 2013 | 04:16 PM
Kam B's Avatar
Kam B
Default bright green liquid
I have a small minor leak from the left hand side of the bay some where.
Had a better look today when I was copper greasing my front pads
Leak is coming from a metal pipe on the drivers side but it's bright green and the water tank has pink coolent
What would that liquid be? Is this leak a common problem?
Old Aug 26, 2013 | 04:23 PM
James B's Avatar
James B
I thought bright green was the air con system
Old Aug 26, 2013 | 04:26 PM
GVK.'s Avatar
GVK.
Yep, AC- it's dye in the R134 refrigerant.
Old Aug 26, 2013 | 04:37 PM
Kam B's Avatar
Kam B
How odd I thought it was the coolent!
How do I go about fixing it?
Old Aug 26, 2013 | 04:49 PM
GVK.'s Avatar
GVK.
Depends if it's a crack in the pipe itself or just a seal on a joint.
Just a thought, some times coolant looks different colours, so just make sure it is/isn't ac leak or coolant.
Old Aug 26, 2013 | 05:19 PM
Kam B's Avatar
Kam B
Cheers mate
Old Aug 27, 2013 | 09:47 PM
lowman's Avatar
lowman
the green stuff is tracking dye that is added when the AC is refilled...so that you can spot where there is a possible leak in the AC system.
you are supposed to use an UV light and glasses to spot the leak..as it is ultraviolet color...so ..if you can actually see that much liqiud...its a big leak.
does your AC work at all?its should not work if its a leak that big...even if the AC is missing a couple of hundred grams of AC refrigerant...the system will not work.
Old Aug 28, 2013 | 09:08 AM
Kam B's Avatar
Kam B
It's not a big leak maybe a drop will come out once every two days
Old Aug 29, 2013 | 08:46 PM
lowman's Avatar
lowman
sounds like its powersteering fluid you got coming out..
the AC is not fluid..so it should not come out in drop form..
Old Aug 29, 2013 | 10:21 PM
HarryRS's Avatar
HarryRS
It's your power steering pipe they rot and leak away slowly. Take your front bumper off and look above your chargecooler rad you should notice it letting out little drops. They've made a steel one so it does not rot get one ordered before it gets worst.
Old Aug 30, 2013 | 04:58 AM
Kam B's Avatar
Kam B
Cheers. Just order from Ford or somewhere else?
Old Aug 30, 2013 | 08:38 AM
Kam B's Avatar
Kam B
Harry I noticed the leak when I took drivers side wheel off as the metal pipe can be seen from there and it was slightly dripping
Old Aug 30, 2013 | 09:21 AM
HarryRS's Avatar
HarryRS
Yeah it gets worse after time mate, mine started off a little leak and then started making power steering noises. Check your reservoir and see if it's low.
Best place to get the part from is Carparts express.
Old Aug 30, 2013 | 10:31 AM
bassboy's Avatar
bassboy
Sounds like the above pipe to be honest Kam...cant remember for the love of God where I got mine from now.
There is also a coolant pipe which usually rots away to
Old Aug 31, 2013 | 10:10 AM
lowman's Avatar
lowman
buy a new standard fordproper..its did last for ten years before it started to go bad...
Old Aug 31, 2013 | 10:36 AM
st220kyle's Avatar
st220kyle
Ford coolant/anti freeze is bright green now, I've just had water pump changed and that's what they filled it back up with
Old Aug 31, 2013 | 10:54 AM
RichieST's Avatar
RichieST
Is it? I bought some gen. ford antifreeze from my dealer a couple of weeks ago and it was still the pink stuff.
Old Aug 31, 2013 | 11:10 AM
st220kyle's Avatar
st220kyle
Definitely, it was pink when I dropped it off and now its bright green! + some of it was splashed over the engine bay!
Old Sep 7, 2013 | 03:32 PM
FRS-199's Avatar
FRS-199
Sounds like the coolant pipe in the inner wheel arch.... common issue
Old Sep 7, 2013 | 03:53 PM
JamboRS's Avatar
JamboRS
focus rs 1672
wrong coolant then
focus rs coolant should be pink and has a 5 year life,the green has a 3 year life.
they cant be mixed im sure so better hope all your coolant was flushed out.
Old Sep 7, 2013 | 04:17 PM
Kam B's Avatar
Kam B
Looks like a coolent flush in on the cards then
timsrs
Nov 13, 2018 11:48 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Bransby
Sep 11, 2015 01:09 AM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
