2007 transits electrics
Old Aug 17, 2013 | 11:00 PM
Jason murray's Avatar
Jason murray
Default 2007 transits electrics
I have a 2007 reg transit having a prob with the rear lights.. When i turn my indicator left all the left hand side lighhts work when i indicate right my right indicator and fog flash.. When the park lights are on only 1 side will work all break light work. In bad need of help checkd all fuses and earths and are perfect and all the right bulbs
Old Aug 18, 2013 | 12:12 PM
Check the connections on the back light clusters they normaly corrode.
Old Aug 18, 2013 | 12:20 PM
Jason murray
Ya i took all them apart. Would that make them flash together? I sprayed them with wd and dirt remover no joy cant find a break on the line. ??
Old Aug 18, 2013 | 03:54 PM
james kiely's Avatar
james kiely
as glenn said jason clean both sides of connections ,but sometimes its easier to buy new bulb holders as they aint too dear and tend to give a bit of trouble .
Old Aug 18, 2013 | 03:58 PM
There hasnt been a single filament bulb put in where the twin filamnet bulbs go.
Old Aug 18, 2013 | 04:19 PM
Jason murray
Ya i have new bulb holders i didnt get new connection were the cables are tho. All bulbs are in the right places i dont under stand the earth is prfect 2.
Old Aug 18, 2013 | 04:36 PM
GVK.'s Avatar
GVK.
Have a look at your main fuse box/body control module, may have had water ingress.
Bloke at work had some weird electrical faults with one and was found to have water in it.
These are only programmable by dealers or anyone with IDS , and I think the As Built data needs to be downloaded from Ford to programme the new module.
Old Aug 18, 2013 | 04:39 PM
Jason murray
Is that the fuse box behind the glove box or under the bonnett? This really has me confused ha
Old Aug 18, 2013 | 04:53 PM
GVK.'s Avatar
GVK.
Glove box.
Old Aug 18, 2013 | 04:57 PM
Jason murray
Ya tryed all them all good and all fuses in both are good
Old Aug 19, 2013 | 08:57 PM
Jason murray
Would the front lights earths affect the back lights. I found 1 under neath and its in a bad way. Thanks
Old Aug 19, 2013 | 09:11 PM
Harryh24's Avatar
Harryh24
run a direct earth from battery and test it to see if improves.
Old Aug 19, 2013 | 09:15 PM
Jason murray
Would i go frm the battery and fix it on the back where the old earths are or what sorry not good at electrics thanks
Old Aug 19, 2013 | 09:18 PM
GVK.'s Avatar
GVK.
Fix the earths and try it. It's worth checking the fusebox properly (even if it means taking it out) for water ingress
Old Aug 19, 2013 | 09:19 PM
Jason murray
Ya i stripped every thing dwn theres power in every fuse in it 2 ill try new earths next see how it goes
Old Aug 19, 2013 | 10:18 PM
Harryh24's Avatar
Harryh24
just run a provisional one around the outside of the van to test to see if it improves, if it does then you can either find the problem or just put a new cable from the light connector and bolt direct to the chassis by it. it defiantly sounds like a bad earth to me.
Old Aug 20, 2013 | 06:41 PM
DazC's Avatar
DazC
Only common issue is wrong bulbs or corroded plug/socket/bulb holders.
Old Aug 20, 2013 | 09:16 PM
Jason murray
Got it sorted. Who ever tryed to do a job on it before me made a ryt bollox of it indicator wire was connected to fogs brakes were indicators and so on.. Made 2 earhts under the van which were rotted away.
Old Aug 21, 2013 | 04:31 AM
At least its sorted matey.
Old Aug 21, 2013 | 08:14 PM
Jason murray
Ya sorted no thanks to the cowboy that tryed fit a towbar on it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
NC53
Sep 13, 2015 03:05 PM
