Starting issue mondeo130 04 driving me mad!!!
Old Aug 13, 2013 | 01:50 PM
Rubster's Avatar
Rubster
Default Starting issue mondeo130 04 driving me mad!!!
Hi everyone,
First time on the forum and I already need your help!!! I have an 04 130 ghia x mondeo which has just had 4 reconditioned injectors fitted and an update by a ford technician. This was done due to the usual rough running and always going into limp mode. Now those issues have now been resolved since picking the car up especially when warm ( but does happen when cold too but not always) it won't rev above 500 rpm and doesn't have any throttle response. This usually lasts from 10 -30 seconds and occasionally takes2-3 times to start. The car has since been to another ford technician and confirmed the Ecu had all latest software and the PCM updated so I am all out of ideas!!! Car runs lovely once it clears although sounds knocky. Also if you keep starter going for a little longer once she's fired up the problem doesn't occur PLEASE HELP ITS DRIVING ME UP THE WALL!!!!!!
Old Nov 4, 2013 | 11:15 PM
Slik Johnson's Avatar
Slik Johnson
Bump. I have this issue to
Old Nov 11, 2013 | 06:21 PM
Jensenmotorsport's Avatar
Jensenmotorsport
It could be the injectors, in norway we never use recond injectors, it will always be the problem her
j.hammond1
30
Oct 31, 2021 05:28 PM
borboyous
Aug 22, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
