focus RS question...
Old Jul 27, 2013 | 05:25 PM
Westy's Avatar
Westy
Default focus RS question...
Slight issue with FRS...
When the fan kicks it the revs drop and it hunts slightly until they turn off again. Any ideas....
And what temperature do these cars run when just out on a normal run. Last one, at what temp should the fans kick in..
Thanks.
Old Jul 27, 2013 | 06:44 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Westy, get yourself on to the RS Owners club in the Mk1 Focus RS forum and ask the same questions on there. There'll be a few guys that will give you all the info you need.
Old Jul 27, 2013 | 06:56 PM
Westy's Avatar
Westy
Cheers mate.
Old Jul 27, 2013 | 08:03 PM
adsrs1's Avatar
adsrs1
if you have got a scan gauge you should see temps between 95 and 105 normal running and the fans should kick in at about 112 and go off again when they drop to 106
Old Jul 27, 2013 | 08:06 PM
GribbiN's Avatar
GribbiN
You are aware of the auto air con function?
Old Jul 27, 2013 | 08:40 PM
Shings's Avatar
Shings
I thought it was 118 they kicked in at, to be honest the fans will draw and it will drop the revs a bit. I've had no problem with mine. Ultimately if the fan kicks in and out you've nowt wrong.
Old Jul 27, 2013 | 08:59 PM
Westy's Avatar
Westy
Yes have a scan gauge. Fans kick in at 110 and drop temperature but just thought it seemed high.
I'm still thinking about the rs turbo cvh that didn't run that hot lol
Auto air con ???
Old Jul 27, 2013 | 09:05 PM
Shings's Avatar
Shings
That fine - I believe the sensor isn't actually the water but is cyclinder head temp - RSOC Fan Boys will tell you more.
Old Jul 27, 2013 | 09:06 PM
adsrs1's Avatar
adsrs1
the air con comes on if you have any of the heater controles turned on to the orange /yellow markers on the heater controls even if you dont have the aircon switched on these cars are designed to run warm you could also try getting a cpe deflector pannel to keep charge temps down what are your charge temps running at and do you have a constant stream of water in the charge cooler tank
the scn gauge does read the temp at the ack of the head so the water temps are abut 10degrees lower
Old Jul 27, 2013 | 09:08 PM
Westy's Avatar
Westy
Cheers Shings.
Adsrs - I see what you mean now about the air con. Thanks.
It doesn't run a charge cooler, it's been removed and has an intercooler.
Old Jul 27, 2013 | 09:24 PM
adsrs1's Avatar
adsrs1
with an fmic you wont have the problem of the charge cooler pump packing in
Old Jul 27, 2013 | 09:26 PM
Westy's Avatar
Westy
Yeah I've heard the charge coolers and parts can pack up etc.
Any ideas ss to why it hunts a bit when fan kicks in please ?
Old Jul 27, 2013 | 09:27 PM
Westy's Avatar
Westy
And last question.. it has blufin, can these run on normal unleaded or is super unleaded required
Old Jul 27, 2013 | 09:30 PM
adsrs1's Avatar
adsrs1
i would only run the car on 97+ fuel as these cars dont have a knock sensor and what is the battery voltage on the scan gauge
Old Jul 27, 2013 | 09:32 PM
Westy's Avatar
Westy
Super then.. thanks.
Will check voltage.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
