MK1 FRS Turbo replacement
Has anyone done a guide on this? cant seem to find one, is there an order you should remove the pipes and bolts etc? any help or links to a guid would be muchly appreciated.
Bassically just remove the intake pipe, vband clamp for downpipe, vacuum pipe into the turbo and actuator, oil feed and return, water feed and return. i took the manifold off and then undid the turbo from the braket and lifted out....
Wilsfoci
15
30-03-2016 10:26 PM
Matt Baxter
16-09-2015 08:30 PM
saph in dorset
14-08-2015 10:10 AM
