loads of rs turbo bits , zetec bits updated offers
Old Jul 27, 2013 | 11:03 AM
stuart collins's Avatar
stuart collins
Default loads of rs turbo bits , zetec bits updated offers
the following are new panels just have surface rust
mk4 rear panel £40
mk4 front panel£35
mk4 slam panel £35
mk3/4 complete outer sills £30pair
s2 pass front arch £12 posted
s2 side skirt £8 each or pair £15
s1 side skirt £20 or pair £40
s1 lower front spoiler £25
s1 kit front arches need a bit of work fibreglassing £100
s2 roll bar with brackets £40 posted
s2 roll bar only no brackets £23 posted
s2 rollbar ploy bush mounts £10
rs turbo ecu 20 posted
escort mk3 estate cab rear lights pair £25 posted
10mm blue mag leads nearly new £20 posted
new replacement battery panel mk4 escort £20 posted
rs turbo grey bonnet no vents £20
standard rs turbo exhaust housing £35 posted
radial mounted brake brackets for 300mm discs £16 posted
rear screen £10
side glass£10 each
88spec red rear spoiler £20 posted
s2 rs turbo front brakes groved discs surface rust, green stuff pads £45
standard s2 rear lights £20 posted
Rs1600i rollbar compression strut set up just been powder coated orange 150 posted
fse power boost valve£20 posted
rs turbo coil £15 posted
alternator £30 posted
alternater brackets £12 posted
cossie group a coil £25 posted
standard rs turbo air box £40 posted
diesel and xr3 I gearboxes mk3 and 4 £50 can post for £22
s2 inlet manifolds £15 posted
blue alloy breather tank £15 posted
s2 spot lights no brackets £30 posted a pair
new in the box s1 rs turbo oil pump £45 posted
standard boost hoses job lot 4 hoses £25 posted
s2 top rad hose £15 posted
ford steering wheel boss suit 3 bolt steering wheel £20 posted
s2 engine mount £30 posted
rs turbo ported head very big inlet ports , bare head £ 70
5 speed gearlinkage £32 posted
smoothed cross over pipe for efi conversion needs painting £20 posted
mtx centre shaft and brackets £30
fiesta turbo black breather £15 posted
rs turbo drive shafts £40 pair
fiesta turbo cross over pipe £20
series 1 alloy gearbox mounts £20 each posted
large water swirl pot bout 7in long £30 posted
alloy breather tank square 1.5 litre with - fittings welded on £45 posted
alloy oil breather £40 posted
rs 16i rollbar crossmember only £40 posted
s2 headlights £15 posted each
mk3 headlights £15 posted each
charge pipe £23 posted
8mm ht leads with cap £20 posted
arp stud and nut kit £55 posted
PI shocks believed to be fiesta turbo no springs £50
jamex dampers maybe saxo , may suit a kit car£50
small oil cooler 6in wide with hoses and fittings £40 posted
rs turbo airtec water cooler £35 posted
35psi boost gauge white face rare now £50 posted
steering rack £40posted
rear trailing arms £25 posted
rear arms 1 turbo 1 not no bushes£25 posted each
IF U WANT PICS TXT ME AS CANT UPLOAD THEM ON TO COMPUTER
offers on things but don't take the piss
.........................07817472781.............. ...............
gotech mfi fully mappable ecu idea for rs turbo as runs off the dizzy and gets ride of the poor mfi set up no loom but these are available for £25 , £230 posted
rs turbo efi bottom end new bearings new rings £250
standard cosworth 205 bare engine good runner £1300
cosworth Swedish style plenum £100
got s2 bonnets vents doors boots
will do deals for bits I may need ,I need a full rs2000 engine with engine loom ecu both manifolds or a full escort turbo diesel set up engine turbo loom ecu etc ,t5 box 200 block
Old Jul 27, 2013 | 11:43 AM
mondeomark's Avatar
mondeomark
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
don't purpose you have a Series one body kit and grill?
Old Jul 27, 2013 | 12:03 PM
stuart collins
not got a complete kit think missing 1 front arch
Old Jul 27, 2013 | 04:07 PM
rs_turbo_ant's Avatar
rs_turbo_ant
how much to post good t3 any visable cracks or plat in shaft cheeers
Old Jul 27, 2013 | 11:45 PM
Jmac121's Avatar
Jmac121
Hi mate, I'd like the koni's and springs. Got any pictures and details of age and usage please. Also want the top mount poly bushes and crossmember ones (not sure which these are from
s2 front roll bar poly bush £10 posted
or
s2 rollbar poly bush mounts £13 posted)
do you know what brand they are? cheers
Old Jul 28, 2013 | 11:10 AM
robfiestars's Avatar
robfiestars
Would you sell the cage?
Old Jul 28, 2013 | 12:28 PM
stuart collins
I have sum blue and sum yellow bushes don't no the make , I've sold the cheaper pro flexi 1s
Old Jul 28, 2013 | 12:31 PM
stuart collins
No as I will week the shell getting it out
Old Jul 28, 2013 | 02:04 PM
rs_turbo_ant
how much to post good t3 any visable cracks or play in shaft cheeers
Old Jul 28, 2013 | 04:45 PM
stuart collins
T 3 is now sold
Old Jul 28, 2013 | 05:35 PM
Mungus's Avatar
Mungus
Konis if the above deal falls through please mate
Also have the brake brackets bud !
Old Jul 28, 2013 | 05:55 PM
stuart collins
Escort konis sold
Old Jul 28, 2013 | 06:00 PM
rhinopower's Avatar
rhinopower
Pics of the charge cooler setup? Very keen as its perfect for my sleeper!
Old Jul 28, 2013 | 10:30 PM
B19 JUB's Avatar
B19 JUB
any pics of the pace cooler?
Old Jul 29, 2013 | 01:21 AM
stuart collins
It clear states in the ad if u want pics to txt me as I can't up load pics , what is wrong with people how I can I make it any clearer???????
Old Jul 29, 2013 | 04:48 AM
rsmark86's Avatar
rsmark86
crayon
Old Jul 29, 2013 | 05:18 AM
B19 JUB's Avatar
B19 JUB
oh yeah didn't see that bit lol.chill guy blimey
Old Jul 30, 2013 | 04:07 PM
stuart collins
Now braking the white track car above shell cage panels are not for sale
Brakes , suspension sold
Anything u want give me a txt
Old Aug 2, 2013 | 08:56 AM
stuart collins
more bits add and sold stuff removed offers on above but don't take the piss
Old Aug 7, 2013 | 04:27 PM
stuart collins
price reduced can bring bits to ford fair to save on postage
Old Aug 7, 2013 | 04:54 PM
Mungus's Avatar
Mungus
Hi mate,
Will have the following from you at Ford Fair please:
radial mounted brake brackets for 300mm disks
metering units came off running car only took of as went efi
OK with that?
Huw
07789945455
Old Aug 7, 2013 | 04:57 PM
stuart collins
yes, give me a txt on the day and we can meet up
Old Aug 7, 2013 | 04:59 PM
phil_rs's Avatar
phil_rs
yam yammer
Pics of the spot lights please
Old Aug 8, 2013 | 08:10 PM
mondeomark's Avatar
mondeomark
Hi m8 which arch is missing? and can you send me a pic of the imola's and the BK alloys
my mob is 07708940106 cheers mark
Old Aug 9, 2013 | 01:42 PM
stuart collins
more bits added
Old Aug 24, 2013 | 11:08 AM
stuart collins
bump , offers
Old Aug 25, 2013 | 10:06 AM
mondeo-rs's Avatar
mondeo-rs
Hi m8 interested in the airsearch turbo cooler.
Is it the 1 that turbo water pipe goes to? Is it still availabl?
Old Aug 25, 2013 | 08:20 PM
rs_turbo_ant
How many bolts snapped in housing and do you have the rest of them cheers
Old Sep 25, 2013 | 01:09 PM
stuart collins
most of them ive binned it, I do have 1 with out any snapped let me no if u are still after 1
Old Sep 25, 2013 | 01:15 PM
stuart collins
open to offers and will swap for bits I need w.h.y
Old Oct 20, 2013 | 04:57 PM
rs_turbo_ant
Still got good exhaust housing no cracks and no broke bolts cheers??
Old Oct 30, 2013 | 06:21 PM
3i-bays's Avatar
3i-bays
hi mate, do you still have the swirl pot ? what sort of condition is it in ? I will have it painted but don't really want any dents in it.
cheers
mark.
Old Nov 10, 2013 | 05:44 AM
harrison3300's Avatar
harrison3300
Any s2 5 door skirts & arches in your collection bud?
Old Mar 21, 2014 | 08:04 PM
marky_g's Avatar
marky_g
Fleet Manager
Have you got a black top boost hose sfs or samco?
Old Apr 1, 2014 | 11:29 AM
marky_g's Avatar
marky_g
Fleet Manager
Any headder tanks stu?
Old Apr 1, 2014 | 07:48 PM
MARKYMARKONE's Avatar
MARKYMARKONE
hi
have you still got the fiesta rs turbo cross over pipe
cheers
mark
JoeyBoyden
Jan 4, 2024 02:36 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
